Raspberry Pi Forum Help with assembly of raspberry pi 4
  • Subscribers 705 subscribers
  • Views 2107 views
mltejada
mltejada over 5 years ago
Hello, I bought the canakit raspberry pi 4 starter kit and the neego raspberry pi 4 complete kit. I am trying to help my son who is having difficulties to assemble either (black screen or just not powering up).  Are there video resources that will help me to be able to help him with the assembly?  thank you in advance.
  • Sean_Miller
    Sean_Miller over 5 years ago
    Raspberry Pi Documentation
    Did you put the SD card in it?
    See ya',
    Sean
    • Vote Up +5 Vote Down
  • kmikemoo
    kmikemoo over 5 years ago
    mltejada  There is a slight chance that you have an older stock SD card - possibly with NOOBS.  I would recommend following the links from Sean_Miller (Sean Miller) and reformat the SD card with the latest version of the Raspberry Pi Operating System.  This bypasses a lot of "What if's".  I'm pretty sure there are videos.   https://www.raspberrypi.org/software/          Also, https://www.youtube.com/watch?v=ntaXWS8Lk34  - using the RPi Imager.
    This is also a great learning exercise as it is kind of what you do with the RPi - buy a new SD card and start fresh - or try a different version of OS - or a different image to do something different (like a media server).
  • hugohu
    hugohu over 5 years ago
    Also, in addition to what Sean and Mike posted, could you tell us what the ACT light (green one next to red power light) is doing? Blinking patterns that repeat are error codes.
  • mltejada
    mltejada over 5 years ago in reply to hugohu
    Thanks all for your helpful suggestions. The first fix was the SD card and before I had seen your suggestions we downloaded NOOBs into the SD card and the system initiated a download of raspbian. Once it successfully installed, I clicked on OK expecting the system to reboot but once it did it resulted in a gray screen. @Mike Moore, I will try your suggestions tomorrow.  Thanks again.
  • colporteur
    colporteur over 5 years ago in reply to mltejada
    I recommend the following resource for novice Pi users. https://magpi.raspberrypi.org/books/beginners-guide-4th-ed  Unfortunately for you, I am a reader more than a watcher of videos so you get a book reference rather than a picture show.
    The resources that have chimed in are pretty knowledgeable and no doubt will get you sighted in. There are a number of versions of this book depending on the Pi model you have. The pictures I find aid in the understanding of the technical stuff.
    Good luck.
  • colporteur
    I just received this link from Raspberry Pi the title, Setting up your Raspberry Pi, appears to match your need.
    https://projects.raspberrypi.org/en/projects/raspberry-pi-setting-up?mc_cid=665e2163c5&mc_eid=2cb9790018
    I have used these resources for other education related projects and found them useful, it might be helpful in your endeavour.
