Raspberry Pi Forum Raspberry PI 3 Dead
  • Replies 33 replies
  • Subscribers 710 subscribers
  • Views 4777 views
  • raspberry pi 3
Raspberry PI 3 Dead
k5at
k5at over 10 years ago
I got my PI 3 today, and it's DOA.  It comes up to the rainbow screen and hangs.  I measured the 5V and 3.3  volt pins and they are OK.
Has anyone else had this issue?
Herb
Carrollton, TX
    shabaz over 10 years ago in reply to k5at
    Reading your pi3_wifi_test.tiff screenshot you're transmitting at 1496dBm which as you know a 5V 4A supply cannot achieve.
    So I'd say there are driver or some other build issues in the software currently that somehow you have hit. Did you make any unusual modifications to settings that perhaps the driver is getting confused with? Anyway for now, I suggest to use an external 802.11 USB adapter as with your Pi 2.
    I have seen other issues with the 802.11 on the Pi 3, but not the one you have seen. It looks like the 802.11 capability is not fully ready for prime-time in the software, so it might be worth waiting for an update or two.
    EDIT: For what its worth, I configured from the command line (the instructions are on the raspberrypi.org site). I did not use the graphical desktop environment. Perhaps there is an inconsistency between what the GUI displays and what it configures, leading to some error with a config register which causes it to configure itself to an impossible power level. This is speculation of course.
    EDIT2: I just compared, and my Pi 3 (which does not suffer the wireless symptoms that you mention) also displays 1496dBm. So it seems a (possibly [not sure] cosmetic) bug in the driver. An external 802.11 USB adapter correctly showed the configured transmit power to be 20dBm. I cannot see anything else unusual in your iwconfig output.
  • clem57
    clem57 over 10 years ago in reply to k5at
    Ok try switching channels:
    sudo iwconfig wlan0 channel N     where N is 1 -11
    Clem
  • k5at
    k5at over 10 years ago in reply to shabaz
    Yes, 1496 dBm is not even close.   20 dBm is = 100 milliwatts at 50 ohms.  I knew 1496 dBm was bogus.
    Seems like there are still issues. and we will be looking for a update to fix.
    thanks for your help
  • k5at
    k5at over 10 years ago in reply to clem57
    tried that already.
    e14 Contributor over 10 years ago in reply to k5at
    Try turning off power management. I have seen quite a few wifi complaints solved by turning it off including mine.
  • clocey
    clocey over 10 years ago in reply to k5at
    Exactly what did you do and what image.  I am having the same issue.  The green light flashes twice and the screen is stuck on the rainbow colors
  • rew
    rew over 10 years ago in reply to clocey
    That is what happens when you have an OS-image on the SD card that was upgraded. A fresh OS-install of say "noobs" will allow the rpi3 to boot.
    I have not investigated the root cause: The upgraded system should be identical to the fresh install, but alas, it isn't.
  • Problemchild
    Problemchild over 10 years ago in reply to k5at
    Probably the power output of a small sun so most likely wrong image
  • rew
    rew over 10 years ago in reply to Problemchild
    You can't imagine how fast the "expressable numbers" grow. IIRC there are about 10^80 atoms in the universe (apparently give-or-take a factor of 100). 1496dBm would be on the order of 10^75 W, or on the order of 10^49 "small suns" (counting ours as "small" and using 4*10^26 W as its power output.)
    shabaz over 10 years ago in reply to Problemchild
