Raspberry Pi Forum RPI 3 nousb
  • Replies 32 replies
  • Subscribers 708 subscribers
  • Views 4726 views
  • frontpage
  • raspberry_pi_space
RPI 3 nousb
I recently got a pi 3 with the 7" touch screen. I set it up with berryboot and installed jessie. I got to were I needed to use a keyboard and that is when I found out the usb ports didn't work.
I went through the following link to try to fix it but nothing there helped.
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=53832
I've tried keyboards and mice from working linux computers, I even tried a powered usb hub and nothing. I've tried running without the touch screen(via ssh) nothing is recognized.
I've tried power supplies from my other pi's with change. Do I need to post dmesg output? Is it possible I got a bum Pi?
-dan
    Here's the dmesg output. I couldn't figure out how to copy just the errors but I managed to copy the whole listing.
    pi@raspberrypi:~ $ dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Initializing cgroup subsys cpuacct
    [    0.000000] Linux version 4.1.19-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #858 SMP Tue Mar 15 15:56:00 GMT 2016
    [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
    [    0.000000] cma: Reserved 8 MiB at 0x3a400000
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] On node 0 totalpages: 241664
    [    0.000000] free_area_init_node: node 0, pgdat 80880fc0, node_mem_map b9bb4000
    [    0.000000]   Normal zone: 2124 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 241664 pages, LIFO batch:31
    [    0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
    [    0.000000] [bcm2709_smp_init_cpus] ncores=4
    [    0.000000] PERCPU: Embedded 12 pages/cpu @bafb0000 s20416 r8192 d20544 u49152
    [    0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
    [    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa22082 bcm2709.serial=0x10b7a724 smsc95xx.macaddr=B8:27:EB:B7:A7:24 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 939376K/966656K available (6064K kernel code, 534K rwdata, 1664K rodata, 444K init, 757K bss, 19088K reserved, 8192K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
        vmalloc : 0xbb800000 - 0xff000000   (1080 MB)
        lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
        modules : 0x7f000000 - 0x80000000   (  16 MB)
          .text : 0x80008000 - 0x807945f0   (7730 kB)
          .init : 0x80795000 - 0x80804000   ( 444 kB)
          .data : 0x80804000 - 0x80889b10   ( 535 kB)
           .bss : 0x8088c000 - 0x809497dc   ( 758 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000] Additional per-CPU info printed with stalls.
    [    0.000000] NR_IRQS:608
    [    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [    0.000026] Switching to timer-based delay loop, resolution 52ns
    [    0.000248] Console: colour dummy device 80x30
    [    0.001292] console [tty1] enabled
    [    0.001346] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [    0.001413] pid_max: default: 32768 minimum: 301
    [    0.001734] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001777] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.002764] Initializing cgroup subsys blkio
    [    0.002813] Initializing cgroup subsys memory
    [    0.002860] Initializing cgroup subsys devices
    [    0.002904] Initializing cgroup subsys freezer
    [    0.002954] Initializing cgroup subsys net_cls
    [    0.003023] CPU: Testing write buffer coherency: ok
    [    0.003112] ftrace: allocating 20313 entries in 60 pages
    [    0.048751] CPU0: update cpu_capacity 1024
    [    0.048816] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.048851] [bcm2709_smp_prepare_cpus] enter
    [    0.049005] Setting up static identity map for 0x8240 - 0x8274
    [    0.050782] [bcm2709_boot_secondary] cpu:1 started (0) 17
    [    0.050986] [bcm2709_secondary_init] enter cpu:1
    [    0.051028] CPU1: update cpu_capacity 1024
    [    0.051034] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.051420] [bcm2709_boot_secondary] cpu:2 started (0) 17
    [    0.051586] [bcm2709_secondary_init] enter cpu:2
    [    0.051607] CPU2: update cpu_capacity 1024
    [    0.051613] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.051980] [bcm2709_boot_secondary] cpu:3 started (0) 18
    [    0.052111] [bcm2709_secondary_init] enter cpu:3
    [    0.052132] CPU3: update cpu_capacity 1024
    [    0.052138] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.052201] Brought up 4 CPUs
    [    0.052299] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.052329] CPU: All CPU(s) started in HYP mode.
    [    0.052355] CPU: Virtualization extensions available.
    [    0.053044] devtmpfs: initialized
    [    0.071862] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [    0.072130] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.072982] pinctrl core: initialized pinctrl subsystem
    [    0.073532] NET: Registered protocol family 16
    [    0.078653] DMA: preallocated 4096 KiB pool for atomic coherent allocations
    [    0.079626] bcm2709.uart_clock = 48000000
    [    0.083898] bcm2709: Mini UART enabled
    [    0.083965] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.084012] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.084188] Serial: AMBA PL011 UART driver
    [    0.084258] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
    [    0.084458] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.149483] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
    [    0.149554] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
    [    0.150142] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
    [    0.150178] bcm2708-dmaengine 3f007000.dma: dma_debug:0
    [    0.150761] SCSI subsystem initialized
    [    0.150964] usbcore: registered new interface driver usbfs
    [    0.151071] usbcore: registered new interface driver hub
    [    0.151189] usbcore: registered new device driver usb
    [    0.151750] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-15 14:47
    [    0.178847] Switched to clocksource arch_sys_counter
    [    0.220293] FS-Cache: Loaded
    [    0.220575] CacheFiles: Loaded
    [    0.229919] NET: Registered protocol family 2
    [    0.230881] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.231022] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.231232] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.231347] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.231416] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.231740] NET: Registered protocol family 1
    [    0.232071] RPC: Registered named UNIX socket transport module.
    [    0.232104] RPC: Registered udp transport module.
    [    0.232132] RPC: Registered tcp transport module.
    [    0.232159] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.233139] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [    0.234210] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.247619] VFS: Disk quotas dquot_6.6.0
    [    0.247952] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.250054] FS-Cache: Netfs 'nfs' registered for caching
    [    0.250984] NFS: Registering the id_resolver key type
    [    0.251051] Key type id_resolver registered
    [    0.251080] Key type id_legacy registered
    [    0.253141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
    [    0.253301] io scheduler noop registered
    [    0.253341] io scheduler deadline registered (default)
    [    0.253636] io scheduler cfq registered
    [    0.255931] BCM2708FB: allocated DMA memory fa800000
    [    0.255978] BCM2708FB: allocated DMA channel 0 @ f3007000
    [    0.262569] Console: switching to colour frame buffer device 100x30
    [    0.268097] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
    [    0.271309] console [ttyS0] disabled
    [    0.272996] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
    [    1.471429] console [ttyS0] enabled
    [    1.479713] vc-cma: Videocore CMA driver
    [    1.487782] vc-cma: vc_cma_base      = 0x00000000
    [    1.497193] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
    [    1.507700] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
    [    1.518296] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
    [    1.544732] brd: module loaded
    [    1.558270] loop: module loaded
    [    1.565835] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
    [    1.580203] Loading iSCSI transport class v2.0-870.
    [    1.590457] usbcore: registered new interface driver smsc95xx
    [    1.601518] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    1.812823] Core Release: 2.80a
    [    1.819620] Setting default values for core params
    [    1.829093] Finished setting default values for core params
    [    2.040132] Using Buffer DMA mode
    [    2.047135] Periodic Transfer Interrupt Enhancement - disabled
    [    2.058301] Multiprocessor Interrupt Enhancement - disabled
    [    2.069060] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    2.077859] Dedicated Tx FIFOs mode
    [    2.085582] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
    [    2.105141] FIQ FSM acceleration enabled for :
    Non-periodic Split Transactions
    Periodic Split Transactions
    High-Speed Isochronous Endpoints
    [    2.139039] dwc_otg: Microframe scheduler enabled
    [    2.139093] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417288
    [    2.150401] WARN::hcd_init_fiq:413: FIQ ASM at 0x804175f8 length 36
    [    2.162292] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89c000
    [    2.173802] dwc_otg 3f980000.usb: DWC OTG Controller
    [    2.183605] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [    2.197206] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
    [    2.208010] Init: Port Power? op_state=1
    [    2.216063] Init: Power Port (0)
    [    2.223115] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    2.235827] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.249236] usb usb1: Product: DWC OTG Controller
    [    2.258512] usb usb1: Manufacturer: Linux 4.1.19-v7+ dwc_otg_hcd
    [    2.269934] usb usb1: SerialNumber: 3f980000.usb
    [    2.279745] hub 1-0:1.0: USB hub found
    [    2.287470] hub 1-0:1.0: 1 port detected
    [    2.295822] dwc_otg: FIQ enabled
    [    2.295832] dwc_otg: NAK holdoff enabled
    [    2.295840] dwc_otg: FIQ split-transaction FSM enabled
    [    2.295871] Module dwc_common_port init
    [    2.296130] usbcore: registered new interface driver usb-storage
    [    2.307677] mousedev: PS/2 mouse device common for all mice
    [    2.319021] bcm2835-cpufreq: min=600000 max=1200000
    [    2.328814] sdhci: Secure Digital Host Controller Interface driver
    [    2.340458] sdhci: Copyright(c) Pierre Ossman
    [    2.349336] sdhost: log_buf @ ba813000 (fa813000)
    [    2.428878] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    2.461683] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
    [    2.472738] mmc-bcm2835 3f300000.mmc: DMA channel allocated
    [    2.488932] Indeed it is in host mode hprt0 = 00021501
    [    2.499746] mmc0: host does not support reading read-only switch, assuming write-enable
    [    2.517253] mmc0: new high speed SDHC card at address 59b4
    [    2.518964] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.519332] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.519454] hidraw: raw HID events driver (C) Jiri Kosina
    [    2.519642] usbcore: registered new interface driver usbhid
    [    2.519645] usbhid: USB HID core driver
    [    2.520049] Initializing XFRM netlink socket
    [    2.520074] NET: Registered protocol family 17
    [    2.520182] Key type dns_resolver registered
    [    2.520610] Registering SWP/SWPB emulation handler
    [    2.559401] registered taskstats version 1
    [    2.559581] vc-sm: Videocore shared memory driver
    [    2.559590] [vc_sm_connected_init]: start
    [    2.560770] [vc_sm_connected_init]: end - returning 0
    [    2.562088] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
    [    2.665718] Waiting for root device /dev/mmcblk0p7...
    [    2.665935] mmcblk0: mmc0:59b4 NCard 7.48 GiB
    [    2.669939]  mmcblk0: p1 p2 < p5 p6 p7 >
    [    2.687522] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    2.688871] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    2.689002] Indeed it is in host mode hprt0 = 00001101
    [    2.689082] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    2.690629] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    2.693407] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    2.758741] EXT4-fs (mmcblk0p7): INFO: recovery required on readonly filesystem
    [    2.772173] EXT4-fs (mmcblk0p7): write access will be enabled during recovery
    [    2.783770] mmc1: new high speed SDIO card at address 0001
    [    2.889145] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
    [    2.901639] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    2.915491] hub 1-1:1.0: USB hub found
    [    2.923240] hub 1-1:1.0: 5 ports detected
    [    3.208885] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    3.319124] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
    [    3.331945] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    3.348188] smsc95xx v1.0.4
    [    3.411904] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b7:a7:24
    [    5.170328] EXT4-fs (mmcblk0p7): orphan cleanup on readonly fs
    [    5.181938] EXT4-fs (mmcblk0p7): 1 orphan inode deleted
    [    5.192195] EXT4-fs (mmcblk0p7): recovery complete
    [    5.513869] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    [    5.528810] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
    [    5.553300] devtmpfs: mounted
    [    5.560555] Freeing unused kernel memory: 444K (80795000 - 80804000)
    [    5.908700] random: systemd urandom read with 68 bits of entropy available
    [    5.925167] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
    [    5.950989] systemd[1]: Detected architecture 'arm'.
    [    6.121309] NET: Registered protocol family 10
    [    6.131734] systemd[1]: Inserted module 'ipv6'
    [    6.143814] systemd[1]: Set hostname to <raspberrypi>.
    [    6.531286] systemd[1]: Expecting device dev-ttyS0.device...
    [    6.544947] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
    [    6.559596] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    6.573933] systemd[1]: Starting Remote File Systems (Pre).
    [    6.587167] systemd[1]: Reached target Remote File Systems (Pre).
    [    6.599102] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
    [    6.617868] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [    6.637245] systemd[1]: Starting Encrypted Volumes.
    [    6.649601] systemd[1]: Reached target Encrypted Volumes.
    [    6.660454] systemd[1]: Starting Swap.
    [    6.670729] systemd[1]: Reached target Swap.
    [    6.679588] systemd[1]: Expecting device dev-mmcblk0p6.device...
    [    6.693376] systemd[1]: Starting Root Slice.
    [    6.704429] systemd[1]: Created slice Root Slice.
    [    6.714012] systemd[1]: Starting User and Session Slice.
    [    6.726927] systemd[1]: Created slice User and Session Slice.
    [    6.738268] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
    [    6.753344] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [    6.766675] systemd[1]: Starting Delayed Shutdown Socket.
    [    6.779758] systemd[1]: Listening on Delayed Shutdown Socket.
    [    6.791082] systemd[1]: Starting Journal Socket (/dev/log).
    [    6.804300] systemd[1]: Listening on Journal Socket (/dev/log).
    [    6.815824] systemd[1]: Starting udev Control Socket.
    [    6.827925] systemd[1]: Listening on udev Control Socket.
    [    6.838533] systemd[1]: Starting udev Kernel Socket.
    [    6.850492] systemd[1]: Listening on udev Kernel Socket.
    [    6.860986] systemd[1]: Starting Journal Socket.
    [    6.872437] systemd[1]: Listening on Journal Socket.
    [    6.882399] systemd[1]: Starting System Slice.
    [    6.893583] systemd[1]: Created slice System Slice.
    [    6.903385] systemd[1]: Starting File System Check on Root Device...
    [    6.919901] systemd[1]: Starting system-systemd\x2dfsck.slice.
    [    6.934115] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    6.946302] systemd[1]: Starting system-autologin.slice.
    [    6.959356] systemd[1]: Created slice system-autologin.slice.
    [    6.970620] systemd[1]: Starting system-serial\x2dgetty.slice.
    [    6.984340] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    6.996516] systemd[1]: Starting Increase datagram queue length...
    [    7.012732] systemd[1]: Starting Restore / save the current clock...
    [    7.033046] systemd[1]: Mounting POSIX Message Queue File System...
    [    7.050265] systemd[1]: Starting Create list of required static device nodes for the current kernel...
    [    7.074139] systemd[1]: Starting udev Coldplug all Devices...
    [    7.131285] systemd[1]: Started Set Up Additional Binary Formats.
    [    7.144193] systemd[1]: Mounting Debug File System...
    [    7.189375] systemd[1]: Starting Load Kernel Modules...
    [    7.208235] systemd[1]: Mounted Huge Pages File System.
    [    7.219177] systemd[1]: Starting Slices.
    [    7.230021] systemd[1]: Reached target Slices.
    [    7.243491] systemd[1]: Mounted Debug File System.
    [    7.255679] systemd[1]: Mounted POSIX Message Queue File System.
    [    7.270713] systemd[1]: Started Increase datagram queue length.
    [    7.311306] fuse init (API version 7.23)
    [    7.321986] systemd[1]: Started Restore / save the current clock.
    [    7.337691] systemd[1]: Started Create list of required static device nodes for the current kernel.
    [    7.361974] systemd[1]: Time has been changed
    [    7.378156] i2c /dev entries driver
    [    7.388297] systemd[1]: Started File System Check on Root Device.
    [    7.403977] systemd[1]: Started Load Kernel Modules.
    [    7.417519] systemd[1]: Started udev Coldplug all Devices.
    [    7.567132] systemd[1]: Starting Apply Kernel Variables...
    [    7.583270] systemd[1]: Mounting Configuration File System...
    [    7.599531] systemd[1]: Mounting FUSE Control File System...
    [    7.605008] systemd[1]: Starting Create Static Device Nodes in /dev...
    [    7.610628] systemd[1]: Starting Syslog Socket.
    [    7.613885] systemd[1]: Listening on Syslog Socket.
    [    7.614051] systemd[1]: Starting Journal Service...
    [    7.621762] systemd[1]: Started Journal Service.
    [    7.773163] systemd-udevd[111]: starting version 215
    [    8.142179] rpi-ft5406 rpi_ft5406: Probing device
    [    8.142600] input: FT5406 memory based driver as /devices/virtual/input/input0
    [    8.469205] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
    [    8.628099] cfg80211: Calling CRDA to update world regulatory domain
    [    8.719024] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
    [    8.719885] usbcore: registered new interface driver brcmfmac
    [    8.966409] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
    [    8.992664] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
    [    9.093632] bcm2835-rng 3f104000.rng: hwrng registered
    [    9.094189] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [    9.392909] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
    [    9.392935] cfg80211: World regulatory domain updated:
    [    9.392944] cfg80211:  DFS Master region: unset
    [    9.392953] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
    [    9.392967] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [    9.392980] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [    9.392992] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
    9.393007 cfg80211(5170000 KHz 5250000 KHz 80000 KHz  160000160000 KHz AUTO(N/A 2000 mBm(N/A
    9.393021 cfg80211(5250000 KHz 5330000 KHz 80000 KHz  160000160000 KHz AUTO(N/A 2000 mBm(0 s
    9.393034 cfg80211(5490000 KHz 5730000 KHz  160000160000 KHz(N/A 2000 mBm(0 s
    [    9.393046] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    [    9.393058] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    [    9.518076] systemd-journald[108]: Received request to flush runtime journal from PID 1
    [    9.868407] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
    [    9.868430] brcmfmac: brcmf_add_if: ignore IF event
    [    9.873886] brcmfmac: power management disabled
    [   10.606396] uart-pl011 3f201000.uart: no DMA platform data
    [   10.994626] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
    [   11.319062] random: nonblocking pool is initialized
    [   11.630989] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [   11.631218] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   13.250045] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   13.253814] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
    [   15.197767] Bluetooth: Core ver 2.20
    [   15.197851] NET: Registered protocol family 31
    [   15.197861] Bluetooth: HCI device and connection manager initialized
    [   15.197884] Bluetooth: HCI socket layer initialized
    [   15.197901] Bluetooth: L2CAP socket layer initialized
    [   15.197939] Bluetooth: SCO socket layer initialized
    [   15.214699] Bluetooth: HCI UART driver ver 2.3
    [   15.214720] Bluetooth: HCI UART protocol H4 registered
    [   15.214730] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   15.214740] Bluetooth: HCI UART protocol BCM registered
    [   15.553447] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   15.553466] Bluetooth: BNEP filters: protocol multicast
    [   15.553489] Bluetooth: BNEP socket layer initialized
    [   25.129810] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
    pi@raspberrypi:~ $
    shabaz over 10 years ago
    Hi Dan,
    How did you get the OS installed without using the keyboard? Could you try downloading Raspbian Jessie (you didn't specify if it was Raspbian or not) and installing that? (For transferring the file onto the microSD card, use Win32DiskImager on a Windows PC or the appropriate software and procedure as described in the getting started section at raspberrypi.org - Apple Mac is probably described there too).
    For the install, ensure there are no ancillary bits like the touch screen connected, just a wired keyboard and mouse (not all wireless ones work) and HDMI and power of course. If you see any rainbow squares on the display, or the red LED on the Pi turning off briefly then these symptoms will mean a better power supply (and/or USB cable with internal heavier gauge wire for power) is needed.
    This part I didn't understand - SSH doesn't use USB. It isn't related, so perhaps it is an install related issue if multiple things are at fault.
    Are you by any chance using the console (serial) connection from the 40-pin header to access your Pi? That has (severe) issues although there are workarounds of sorts.
    Google 'raspberry pi 3 uart baud issue' to see detail about this - in short, the baud rate is unpredictable. Leaving you with no access whenever a clock inside the Pi's BCM.. chip changes frequency. The couple of workarounds address this in a few different ways.
  • clem57
    clem57 over 10 years ago
    Please paste the output of the following
    lsusb -v
    e14 Contributor over 10 years ago in reply to shabaz
    I used berryboot to install the latest Raspbian jessie.
    BerryBoot v2.0 - bootloader / universal operating system installer
    SSH was the only way I could access the the PI without a keyboard.
    I got new 8gb uSD and berryboot is downloading jessie again.
    e14 Contributor over 10 years ago in reply to clem57
    I'll try that once I have jessie installed on the new card.
    pi@raspberrypi:~ $ lsusb -v
    Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
    Couldn't open device, some information will be missing
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass          255 Vendor Specific Class
      bDeviceSubClass         0
      bDeviceProtocol         1
      bMaxPacketSize0        64
      idVendor           0x0424 Standard Microsystems Corp.
      idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
      bcdDevice            2.00
      iManufacturer           0
      iProduct                0
      iSerial                 0
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength           39
        bNumInterfaces          1
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                2mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           3
          bInterfaceClass       255 Vendor Specific Class
          bInterfaceSubClass      0
          bInterfaceProtocol    255
          iInterface              0
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0200  1x 512 bytes
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x02  EP 2 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x83  EP 3 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0010  1x 16 bytes
            bInterval               4
    Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0 Unused
      bDeviceProtocol         2 TT per port
      bMaxPacketSize0        64
      idProduct          0x9514
      bcdDevice            2.00
      iManufacturer           0
      iProduct                0
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           41
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                2mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         9 Hub
          bInterfaceSubClass      0 Unused
          bInterfaceProtocol      1 Single TT
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0001  1x 1 bytes
            bInterval              12
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       1
          bNumEndpoints           1
          bInterfaceProtocol      2 TT per port
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceProtocol         1 Single TT
      bMaxPacketSize0        64
      idVendor           0x1d6b Linux Foundation
      idProduct          0x0002 2.0 root hub
      bcdDevice            4.01
      iManufacturer           3
      iProduct                2
      iSerial                 1
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceProtocol      0 Full speed (or root) hub
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0004  1x 4 bytes
            bInterval              12
    pi@raspberrypi:~ $
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    Please remove fast Ethernet adapter and try again with same display.
    Clem
    pi@raspberrypi:~ $ sudo apt search fast ethernet
    Sorting... Done
    Full Text Search... Done
    vde2/stable 2.3.2+r586-1 armhf
      Virtual Distributed Ethernet
    pi@raspberrypi:~ $ sudo apt-get remove vde2
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Package 'vde2' is not installed, so not removed
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    How do I remove it?
  • clem57
    Sorry unplug it to see how the hub gets affected.
    There wasn't anything else plugged in. So, I'm starting to think I got a bad pi. I tried Ubuntu mate and the usb ports didn't work with either.
