Raspberry Pi Forum Is it possible to make an intelligence robot with R-Pi ?
  • Subscribers 707 subscribers
  • Views 859 views
  • raspberry
  • robot
  • swarm
premjithav@gmail.com
premjithav@gmail.com over 14 years ago
Hello friends,
Do you have any idea about to make a robot with Pi. I want to build a simple robot with some basic intelligence. You have any reference  pls share...
Thanks in advance..
    I'm a mechanical engineer. I will try to use this little device for my UAV project.
    Of course it's possible to do this, if you take a look at the RPi_serial board here - http://www.bitwizard.nl/wiki/index.php/Raspberry_pi_expansion_system_page#expansion_boards
    This would give you access to control 5 serial ports which would give you control over at least 5 stepper motors.
    You might have to write some software to interface with these but given enough time and effort there is no reason you shouldn't be able to use a RPi to control a robot or even use a GPS module and USB camera to build an intelligent guidance system for it too.
    edit:
    Sorry just spotted there already exists a servo control expansion board which will control 7 servos.
    http://www.bitwizard.nl/wiki/index.php/SPI_Servo
    So depending on what protocol you wanted to use/devices you wanted to control - you have choice of 5 serial ports or 7 servo control interfaces.
    Message was edited by: Leigh de Paor
    I've been thinking about this some more and was wondering how the Microsoft Kinect and/or ASUS XTION Wave device would function as a depth perception, camera for control & feedback. Combined with a GPS device this could be used to power a fairly smart quadrocopter or similar autonomous device.
  • YT2095
    YT2095 over 14 years ago
    having designed and built many robots in the past (and have a current build on the go as well), I find that it`s best to off load as many tasks as possible to smaller controllers, leaving your main control unit free to focus purely on data processing and task delegation.
    so the mobility for instance will be a complete module in it`s own right, memory mapped and served with Address and Data, the same for an arm unit and sensor array.
    doing it this way would also allow you to build a Vitual robot in the Pis memory (or any other processing unit), then it`s simply a matter of data manipulation of these memory/register areas.
    we operate in a similar way ourselves, you don`t Consciously tell your heart to beat or your lungs to breathe, or move your hand if you touch your soldering iron by accident image
    this method can lead to interesting emergent behavior that frequently ressembles Inteligence of sorts.
    hope that helps a little.
  • zardoz99
    zardoz99 over 14 years ago in reply to e14 Contributor
    I'm pretty certain that you could use a Kinect with the Pi. The code already exists to access it from Fedora, and probably other distros as well. I have experimented with the combination and found that they play well together.
    I recommend that you take a look at http://openkinect.org/wiki/Main_Page as a starting point and perhaps join the mailing list.
    For the robot hardware, you could investigate the work being done with Robosapiens from http://www.wowwee.com/en
    e14 Contributor over 14 years ago in reply to YT2095
    http://www.rcheliresource.com/video-mit-uses-autonomous-quadcopter-with-kinect-to-model-3d-environments/
    Interesting use of kinect with autonomous robots here.
    All great information on this thread, thanks.
