Raspberry Pi Forum need power supply
  • Replies 14 replies
  • Subscribers 710 subscribers
  • Views 1662 views
need power supply
cullimore
cullimore over 14 years ago
hi all,
where do i order the mini usb power supply from? or does this come with the Raspberry Pi ?
cheers
  • robotonics
    robotonics over 14 years ago in reply to caydee
    You are correct. I have found that recently to my peril!
    e14 Contributor over 14 years ago in reply to caydee
    Also, stay away from cheap hubs with a 19V power supply and bad capacitors... image
  • rew
    rew over 14 years ago in reply to e14 Contributor
    I bought one of these. (well I got the european version):
    http://www.google.com/products/catalog?q=htc+charger&hl=en&prmd=imvns&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1005&bih=1024&um=1&ie=UTF-8&tbm=shop&cid=11688719650009016602&sa=X&ei=SvB-T42iC4-XOviasP8G&ved=0CHwQ8wIwAQ
    We tested the cable, and it is good enough for the RPI. (I did pay about $13, and not the $2 that is quoted as the best price there).
    I use a powered USB hub. I takes a 5v 2.5mm dc jack to power the hub, then I plug a USB A to micro USB lead to provide the power to the Pi.
    It works well and to remove power from the Pi, I just pull the dc jack from the hub.
