Raspberry Pi Forum need power supply
  • Replies 14 replies
  • Subscribers 710 subscribers
  • Views 1674 views
need power supply
cullimore
cullimore over 14 years ago
hi all,
where do i order the mini usb power supply from? or does this come with the Raspberry Pi ?
cheers
  • robotonics
    robotonics over 14 years ago
    You can get one on Ebay for £7
  • cullimore
    cullimore over 14 years ago in reply to robotonics
    okay many thanks.
    i have a mini usb power lead for my Archos tablet. will this work?
    what voltage ect does it need? is there an offical power supply?
  • robotonics
    robotonics over 14 years ago in reply to cullimore
    Hi Darren
    There is a difference between mini-usb and micro-usb (newer (host/device)) type. Any power supply capable of supplying regulated 5V @850mA (ideal) 700mA min with a Micro-USB plug would be fine.
  • GreenYamo
    GreenYamo over 14 years ago
    Judging by some of the comments on the official RasPi forum, you may want to spend a little more and avoid ebay, or at least the very cheap versions.
    If you have a modern mobile phone, it is highly likely that the charger for it will work with the Pi, as this was the reason they chose this power source in the first place.
    I have a charger for an HTC desire and a second one for the Samsung Galaxy SII and they are both rated at 5V, 1 amp which will be fine.
  • cullimore
    cullimore over 14 years ago in reply to GreenYamo
    i may use the charger on my ARCHOS G9 then ( i`ll have to check the voltage etc when i get home )
  • cullimore
    cheers, just checked my ARCHOS G9 tablet charger and thats a 5v 1.5A. hopefuly this should work.image
  • robotonics
    Yes, that will work just fine image
    Will the iphone 4 power adapter work?
  • caydee
    caydee over 14 years ago in reply to e14 Contributor
    Yes, iPhone power adapter should work fine.  I believe the genuine Apple one is rated at 1A.  If you have something other than the official Apple one, get out your microscope and check the rating label on it.
    While we are here, it's worth mentioning that you should probably be a bit careful with the USB cable you use.  I have found that some micro USB cables are inadequate for charging phones (although they are fine for data transfer), so I would expect them to be inadequate for powering the Rpi.  The problem cables have been very cheap ones, or thin flat ones on a winding extender gizmo. Blackberry micro USB cables can be found fairly cheaply on an auction site near you, and I've found them to be very good.
  • caydee
    caydee over 14 years ago in reply to caydee
    Following on from my previous comment, the same goes for USB extension cables.  I've found that cheap ones are no good for powering/charging devices.  So for powering the Rpi I would recommend sticking to USB cables and extensions from one of the well-known cable or phone manufacturers (Belkin, Molex, HTC, Motorola, Samsung, Blackberry, Sony etc.).
