Raspberry Pi Forum Seneca breaks silence on Fedora Remix
  • Replies 84 replies
  • Subscribers 709 subscribers
  • Views 10075 views
  • raspberry
  • help
  • helpme
  • raspberrypi
After a puzzling two months of silence from Seneca with regard to
plans for fixing the withdrawn Fedora Remix, there is a blog post
indicating that work is starting with the beginning of summer,
including fixing the problem with attempting to change the timezone.
http://roottothehead.blogspot.com/2012/05/summer-at-seneca.html
  • GreenYamo
    GreenYamo over 14 years ago
    Better late than never I guess. I think I downloaded this somewhere, now i've got my pi perhaps i'll load it up and see how broken it is.
    If it is badly broken, how did it get released ? Or is that a silly question ?
    e14 Contributor over 14 years ago in reply to GreenYamo
    Steve,
      That isn't a silly question.  Fedora is supposedly the primary OS for this device,
    so care should have been taken by all parties involved, to ensure that it worked
    reasonably well.
      Apparently from what I can gather, the foundation isn't putting much funding into
    development of Fedora.  Seneca lists their sponsors, but doesn't include the
    foundation.  The foundation has apparently provided one alpha board, but no
    beta boards.  I don't know about production boards.
      The development at Seneca was apparently done in connection with a class,
    SBR600 taught by Chris Tyler:
    http://zenit.senecac.on.ca/wiki/index.php/SBR600
    The problems with the Remix were found immediately upon release, and
    included problems with login, and problems setting timezone.  The login
    problem apparently happens if the RPi is booted without being connected
    to the network to set its time/date.  So it appears that no beta testing was done
    by anyone in a different timezone than Seneca, or by anyone without a network
    connection at boot time.
    Other problems, such as general slowness and needing frequent reboots
    may have been known at time of release, but may have been deferred in order
    to meet the launch schedule.  These problems may be more difficult to fix.
    I believe the login and timezone problems involved simple scripting errors
    involving lifetime of environment variables.
    I think much of the RPi work at Seneca was piggybacking on work for OLPC,
    but I think OLPC is moving to ARM version 7,  at least for its newer machines.
    We have yet to be told if Fedora will continue to be the primary OS,
    and if so, what level of support will be provided, particularly in the way of
    security updates and bugfix updates.  The lack of any support or updates
    so far is not encouraging.
    RaspberryPi org's downloads page no longer even lists Fedora 14 Remix - until recently it had noted that it was buggy and recommended Debian Squeeze instead, so from the Downloads page at least Debian Squeeze is the defacto standard.  Chris Tyler's CDOT group at Seneca do seem to be gearing up for two imminent releases, a new build of Fedora 17 due May 24, and some fixes and updates for 14 - source is this meeting from their wiki: http://zenit.senecac.on.ca/wiki/index.php/Fedora_ARM_Meeting_2012_May_02
    RedHat Charges $299 a year for a subcription for a fully supported version of Red Hat Enpterprice Linux for workstations on x86. How much are you willing to pay for an fully supported version of GNU/linux for ARM so that you actually have the right to demand an stable, bug-free and constantly updated release?
    Hasn't this kind of missed the boat now?
    I started with the Debian build and I am quite happy with it.  I don't think I'll be bothering with it myself.
    Even if they fix all the bugs will it really be worth using?
    The beauty of Linux and opensource is that there are flavors for all tastes and tastes for all flavors.
    IMHO that's also probably its biggest weakness.  As a relative newcomer to Linux, I think the choice has delayed me from getting into Linux for years.
    Zeta,
      The level of support I expect depends on what I'm told to expect.
    The FAQ on this website says:
    "UPDATED AT 12:05 pm GMT 15 March
    Q. Why have you temporarily removed the Fedora download?
    A. We want you to be up and running as quickly as possible. There are 3 Linux operating systems for the computer and when the Fedora Remix became available, we tested it on our Raspberry Pi to make sure it was easy to use.  We found issues with the username & password authentication that prevented access to the operating system, effectively making it a bit unusable. To be really clear though, this issue is to do with the software, not the Raspberry Pi board itself. We’ve fed this back to the guys at Fedora, and they’re already working on a new release.  When Fedora have fixed the issue, and element14 with the Raspberry Pi foundation have successfully tested it, we’ll bring the Fedora Remix download back to you.  Until then, we recommend the Debian “Squeeze” distribution that’s available in our Download Center."
    I gathered from this, and from my understanding that the Seneca SBR600 course was only at "midsemester" when they made the original release, that they would quickly release an update with at least the login and timezone bugs fixed.
    On the RPi.org forum, JamesH wrote:
    "by jamesh » Mon Mar 12, 2012 8:51 pm
    It's been covered before, but Fedora is the recommended/standard distro. This is because we NEED a standardised distro for the educational release - we need people to be able to say -"We are using your distro and your stuff doesn't work", rather than "I've got this random distro I made and your stuff doesn't work". In the first case we know we have a problem. In the second case, all bets are off - could be anything.
    That said, we heartedly encourage people to use whatever distro they want. Just don't expect top level tech support from the Foundation itself, on Foundation released packages. We'll try, but we cannot promise anything on other distros, the support burden is too high."
    I gather from this that the foundation does intend to provide top level tech support for their primary distro.
  • morgaine
    morgaine over 14 years ago in reply to e14 Contributor
    Given the relative lack of power of Raspberry Pi's CPU and its poor support for disk storage, I expect the "best" distro for the Pi to end up being the one that is most cut down and optimized.  It's far too early to tell which this will be, but I strongly suspect that it won't be any of the usual desktop distros because they're the opposite of cut down and optimized.
    For experts, a distro is probably defined by its package manager, but if a bespoke Pi distro were to base itself on RedHat, Debian or Ubuntu packages, would it still be RedHat, Debian or Ubuntu?
    Perhaps not, because from a user's perspective, "normal" distros tend to be defined by their desktops.  You might think that the character of a distro could be preserved despite the slimming down, but once you've thrown out the bulk of a horrendously bloated desktop manager, what you're left with is something quite different.  A newbie user of that desktop distro may not recognize their surroundings anymore.
    It's undoubtedly a contentious issue, but the big distros are probably defined by their desktop bloat. image
    Morgaine.
    "... Just don't expect top level tech support from the Foundation itself, on Foundation released packages. We'll try, but we cannot promise anything on other distros, the support burden is too high."
    Nowhere they said the Foundation had any intention to provide tech support for any distro. You may expect they offer some help and support when you run Foundation released packages on their Recommended/standard distro. However, the Foundation has not yet released any software package.
