Hi, I've just taken delivery of my Raspberry Pi. I loaded up Debian, hooked it up to my TV via the HDMI connection but the edge of the screen overlaps the screen size. I cannot see the task bar or menu buttons. How can I fix this?
Fergus is on track, but have you already read the very informative wiki?
http://elinux.org/RaspberryPiBoardhttp://elinux.org/R-Pi_Troubleshooting
woo-hoo, it was the overscan settings that i needed, thank you
(OK, so how do I mark this as Answered?)
Kev,
underneath the post that fixed your problem, there is two options: "helpful answer" and "correct answer". The answer(s) that were helpful, click on "Helpful Answer" for the answer that was correct click on "correct answer".
I hope this helps.
(this post does not count)
Glad it worked out for you Kev. I had an underscan issue on my TV and that's where I found the answer. The wiki is a must read for troubleshooting.
Now go do something interesting with your Pi!
Hi everyone,
Just got my Raspberry Pi 3 Model B & 16GB NOOBS pakage, then hocked it up to my HDTV but at first did not have Audio from TV only 3.5 mm jack.
your solution worked for me Thanks.
