Raspberry Pi Forum Boxing up Raspi?
  • Replies 31 replies
  • Subscribers 712 subscribers
  • Views 5097 views
  • the
  • raspi
  • up
  • boxing
Boxing up Raspi?
I would like to think that I could make a box to contain the Raspi, but looking at the Safety Information,
it should be operated in a ventilated environment and not covered.
And of course, it would be electricily safe, wouldn't it?
I have seen a report somwhere that a container was made from Lego bricks!
  • johnbeetem
    johnbeetem over 14 years ago
    Some people have reported problems with RasPi overheating, so putting it in a closed box may not be a good idea.  The RasPi Foundation has been pretty quiet lately about plans for an official case.  Probably the best would be a metal box with a thermal pad on the bottom to take heat away from the 3.3V regulator RG2, the BCM2835 SoC and LAN9512 USB/Ethernet chips.  Or you can have a perforated metal cover like a power supply.  Highest voltage is 5V so you won't be harmed by electricity.  When I get mine, I'm planning to run it on conductive bubble wrap to start, and then if all works out make up a box I can run with the lid off or make a perforated metal lid.
    There are tons of case ideas and discussion at raspberrypi.org.
  • morgaine
    morgaine over 14 years ago
    This is the place for y'all to hang out:  http://elinux.org/RPi_Cases  image
    @John Beetem: I was researching BeagleBone cases today for a new section at http://elinux.org/BeagleBone , and was saddened that this lovely little board has so few casing options.  I guess I'll have to finish work on my 3D printer and design something new. image
    Morgaine.
  • johnbeetem
    johnbeetem over 14 years ago in reply to morgaine
    In the USA you can get a tin of dog treats called Yip Yaps, which are shaped like little bones.  I need to see if the tin is the right size for BeagleBone -- much more humorous than Altoids :-)
    My philosophy on BeagleBoard/Bone is that making your own case is part of the fun.  I adapted a Christmas candy box for my BeagleBoard.  It includes room for my power supply.
  • morgaine
    morgaine over 14 years ago in reply to johnbeetem
    STM32F4-Discovery boards fit *exactly* into hinged 3.5" floppy disk boxes, incidentally. image
    BeagleBone is just a bit too small for them, unless one doesn't mind one end being some way inside the box.
    e14 Contributor over 14 years ago in reply to johnbeetem
    Many thanks for your response. I was also worried about the voltage, but if, as you state, it is only 5, then that's fine.
    The idea of a perforated metal cover/box would seem a good idea. I will get the tools out!
    Thanks again
    e14 Contributor over 14 years ago in reply to morgaine
    Thanks for the link to the "cases" site!
    Good collection, and clever!
  • bhbud
    bhbud over 14 years ago
    Bud has created a box that solves your problems as it has open sides that allows not only for ventilation, but also for easy access to connections including the flat cables and i/o ports that other boxes ignore.  Here's a quick video on it.  http://www.youtube.com/watch?v=GKV29FfZoO4&feature=g-all-lik.  Here is the link to the product on the farnell page - it should be in stock in a few days.  http://uk.farnell.com/bud-industries/ps-11591/raspberry-pi-enclosure-pcb-box/dp/2102397?Ntt=ps-11591.  it is pretty inexpensive also.
  • GreenYamo
    GreenYamo over 14 years ago in reply to bhbud
    But sadly £15.95 delivery to the UK !
    I was going for the Mod my pi case, https://www.modmypi.com/products.php but as they weren't shipping, I bought one of the SK Pang cases http://www.skpang.co.uk/catalog/raspberry-pi-cover-red-p-1077.html
    Even with this relatively small coverage, the Pi seems to get pretty hot so I'm not sure how one will fare with little or no cool air circulation. Perhaps a mod my pi case with a small fan blowing over it. It also seems to be linked to my pi not booting properly after a while, similar problems have been noted elsewhere as John says above.
    It will be interesting to see what happens as more people case thier pi's I guess.
  • bhbud
    bhbud over 14 years ago in reply to GreenYamo
    We are in the process of getting stock to UK, which should cut the costs considerably.  In an open case, heat build up should not be a problem.
  • GreenYamo
    Blair, it is more open than I realised after looking at the video, so it will certainly go on my 'thinking about' list if it is available from the UK direct. Have you had a pi running for a long time in the case ?
    Mine has been on for about an hour in my SK Pang case streaming BBC TV (QI as it happens) and there is quite a heat build up on the top of the case.
