Raspberry Pi Forum Boxing up Raspi?
  • Replies 31 replies
  • Subscribers 712 subscribers
  • Views 5105 views
  • the
  • raspi
  • up
  • boxing
Boxing up Raspi?
I would like to think that I could make a box to contain the Raspi, but looking at the Safety Information,
it should be operated in a ventilated environment and not covered.
And of course, it would be electricily safe, wouldn't it?
I have seen a report somwhere that a container was made from Lego bricks!
  • jamodio
    jamodio over 14 years ago in reply to rew
    The SMSC Ethernet/USBhub chip gets hotter than the SoC, about 120F with the IR gun, the 3.3V regulator almost 100F.
    -J
  • rew
    rew over 14 years ago in reply to jamodio
    Hey, interesting measurements. How hot does the SOC get?
    Who wants to take the trouble to calculate the dissipated power from the thermal characteristics in the datasheet and these measurements? I'm doing other things today. otherwise I might do it later....
  • jamodio
    Pointing the IR gun to the SoC shows about 100-115F, just running the console and responding pings from another machine
    (I found that if I push it with a ping flood the kernel panics, so there are some issues there).
    Answering Morgaine's other question, I've a Roku 2 XS. The enclosure does not have any ventilation holes or fan. I don't have it open but
    pointing the gun to it shows ~100F.
    There is a nice teardown here: http://tek.io/oMCOjx
    -J
  • bhbud
    bhbud over 14 years ago in reply to jamodio
    Keep in mind that the Bud enclosure is the one that gives ventilation, access to the i/o ports and the flat cable, and gives you all of the flexibility you need.  They are in stock in the US, hoping to get them to the UK shortly
  • jamodio
    jamodio over 14 years ago in reply to bhbud
    Are you talking about these ? http://www.budind.com/images/product/large/plastic-boxes-rasp.jpg
    With all due respect, they are so freaking UGLY !!!
    -J
  • bhbud
    Sorry you feel that way - those sketches to do not show it at its best -  have you seen the video?  I think it does it more justice.  http://www.youtube.com/watch?v=GKV29FfZoO4&feature=g-all-lik.  We went with the IR red to allow it more flexibility.
  • jamodio
    I saw the video for the round one that looks more like a tupperware thing for a gelatin pie.
    I use/used BUD enclosures for many projects, I'm sure they can do much better than that.
    -J
  • pjc123
    pjc123 over 14 years ago in reply to jamodio
    -J
    I have also used BUD boxes for many projects.  When I first saw the boxes they proposed, I thought someone was just pulling a prank.....obviously not.  Their good mechanical engineers must have jumped the ship to Apple.
    e14 Contributor over 14 years ago in reply to johnbeetem
    I'd like to see someone water cool this kit. You'd probably have to use a waterblock designed for a North or South bridge, but it would be an interesting theory to see in action.
    e14 Contributor over 14 years ago in reply to bhbud
    "The power consumption on the board is about 8-10 watts..."
    I want to know how you got your R-Pi board to draw 2 amps (5V * 2A = 10 watts) without blowing the fuse. The Pi is specified to draw 700 mA. The input fuse on the production board has a pass rating of 700 mA and a cutoff rating of 1.4 A.  Several people have measured theirs and found that it uses 2 to 3 watts.  One person measured 550 mA when the CPU was running at 100% and also using ethernet.
