Raspberry Pi Forum No HDMI display at Boot
  • Replies 10 replies
  • Subscribers 707 subscribers
  • Views 2685 views
  • hdmi
I can not get the display on my 42 in HDMI TV at boot. This is 1080p at 60Hz
The only way I can get the pi to display is connect to another smaller HDMI TV and wait until I see the
GUI
I then pull the cable from the small set and put it into the large TV and the display shows on the set.
This is the config.txt
config_hdmi_boost=4
hdmi_force_hotplug=1
config_hdmi_boost=4
overscan_top=40
overscan_bottom=40
overscan_left=50
overscan_right=50
    Does this help?
    Setting up HDMI output
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=5&t=5851
    I'm no expert but it sounds like the R-Pi is confused by the EDID info from your larger TV.
    (EDID: When starting the raspberry-Pi asks the TV for information about itself. This information is returned by the TV in a data structure called an 'EDID' block.)
    User 'dom' on the RPi.org forum has been able to assist some users with debugging using EDID info, see for example
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=7348
  • johnbeetem
    johnbeetem over 14 years ago
    I'd try to avoid hot-plugging HDMI.  The cables are supposed to be hot-pluggable, but they have very small contacts and it would not be nice to zap your TV.  The BeagleBoard documentation warns against hot-plugging HDMI.
    Along with jbeale's suggestions, I'd also recommend looking at the RasPi Troubleshooting Wiki: http://elinux.org/R-Pi_Troubleshooting.  Specifically, you might try renaming "config.txt" so that it's not used.  This has cured HDMI problems for some people.
    e14 Contributor over 14 years ago in reply to johnbeetem
    Thanks for the HotPlugging advice. I never knew that.
    As to all the troubleshooting links. I have tried them all to no avail.
    Even renaming config.txt
  • wallarug
    wallarug over 14 years ago in reply to e14 Contributor
    Read my posts on: http://www.element14.com/community/thread/18205?tstart=0  This fixed my problem and might fix yours.
    All fixed (audio + resolution)
    Instuctions for others who may be experiencing the same issue with a TV and the Raspberry Pi:
    1. Install a fresh image (optional)
    2. start-up the Raspberry Pi and let it set itself up (normal set-up) - only on first boot
    3. After you have gone through normal set-up:
         a. Log-in as a normal user (debian image: pi)
         b. Type the command: "sudo nano /boot/config.txt "
         c. Press enter
         d. Type in: "hdmi_drive=2 " [exactly as it is here]
         e. Then press crtl + o
         f.  Press Enter
         g. then press crtl + x
    4. Restart using the command: " sudo shutdown -r now "
    That gets the Raspberry Pi to register the TV as a HDMI device.  You now have sound!  For different resolution:
    5. After you have gone through normal set-up:
         c. Press enter
         d. Type in: "hdmi_group=1 " [exactly as it is here]
              Press Enter
              Type : "hdmi_mode=x "  where x = corresponding number of resolution mode.  See: http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=5851
         f. Press Enter
    6. Restart using the command: " sudo shutdown -r now "
    Now you have desired resolution and Sound!!!
    Happy Raspberry Pi...ing
    e14 Contributor over 14 years ago in reply to wallarug
    I'm afraid that never worked either
  • wallarug
    Try it agian with a fresh image off the raspberrypi website.  Sometimes the image maybe the issue.
    http://www.raspberrypi.org/downloads
    I had tried that and also tried the archlinuxarm image but the same problem applies
  • wallarug
    Try talking to Dom on the Raspberry Pi Forums, Dom does not take part here.
    I have now done so
    I should have stated earlier that I get a display using composite but does that allow audio ?
    I finally have it working with the following
    hdmi_drive=2
    hdmi_mode=16
    There is a bit at the top and bottom of the screen black but OK for now
