Raspberry Pi Forum Will this USB charger work with my Raspberry Pi?
  • Subscribers 706 subscribers
  • Views 442 views
  • mirco-usb
  • raspberrypi
  • adaptor
  • rpi
  • power
segadude
segadude over 14 years ago
It is a Motorola charger that came with my phone. Model: DC4050US0301. On the back it says INPUT: 100 - 240v ~ 50/6Hz 0.2A OUTPUT: 5.1V 850MA. It is the type with a USB port that you plug the USB cable into. Will it work? I'm concerned about the extra .1 volt.
  • fustini
    fustini over 14 years ago
    Hi Brandon,
    5.1V is within the USB spec and won't be a problem.  There are some more insights into why a charger may be designed for above 5.0V in this thread: Re: "Best Power Supply for the Raspberry Pi"?
    Cheers,
    Drew
  • johnbeetem
    johnbeetem over 14 years ago
    According to the spec (i.e., assuming the charger's manufacturer isn't lying to you) it should work.  RasPi is supposed to work with any USB power supply.  USB's voltage spec is 5.0V +/- 5% which varies from 4.75V to 5.25V.  Having an extra 0.1 volt is a good thing since you will probably get a small voltage drop across your USB micro cable and across RasPi's polyfuse F3.
