Raspberry Pi Forum Bluetooth dongle for RasPi
  • Replies 10 replies
  • Subscribers 711 subscribers
  • Views 2541 views
dharr19
dharr19 over 14 years ago
Hello All,
Has anyone found a bluetooth dongle that will work with the Raspberry Pi?
Cheers
David
  • pholynyk
    pholynyk over 14 years ago
    I have found two that work and one that does not. The easiest to identify is a D-Link DBT-122, with ID 07d1:f101, using a Broadcom chip. The other is a little subby thing, nicely half-round, that sticks out about 1 cm. The product ID is 0a12:0001, using a Cambridge Silicon Radios chip. Finally the non-working one is an anonymous blue dongle with a Silicon Wave chip, product ID is 0c10:0000. Apparently it used to work with older versions of BlueZ, so maybe someday it will again.
  • dharr19
    dharr19 over 14 years ago in reply to pholynyk
    Thanksimage
    What is the name of the "little subby thing, nicely half-round, that sticks out about 1 cm. The product ID is 0a12:0001, using a Cambridge Silicon Radios chip"?
    Cheers
    David
  • pholynyk
    pholynyk over 14 years ago in reply to dharr19
    Just to make sure image I went out and bought another one ... for my laptop, yes, that's right.... It's anonymous too. The label says "Bluetooth USB Dongle" - but you already knew that. There is a little sticker on the back that says "Power Data 10020584" but I doubt that helps much. It does say "Made in China', but, again, you knew that, too. Here's a picture of the three of them:
  • morgaine
    morgaine over 14 years ago
    Updating this thread by developer request, to check date sorting.
  • recantha
    recantha over 14 years ago
    I have a Rii Bluetooth Keyboard/Touchpad. Comes with a nano bluetooth dongle that works perfectly.
  • dharr19
    dharr19 over 14 years ago in reply to recantha
    Which particular Rii Wireless Keyboard did you buy?  Finally able to get one now and hoped to go on Amazon and pick one up.  Also, is your keyboard and nano dongle connected to a powered USB Hub?
    Thanksimage
    Cheers
    David
  • recantha
    It was... *sound of furious Googling* This one (though not from this supplier, I used eBay)
    http://gadgetsin.com/rii-mini-wireless-bluetooth-keyboard-with-touchpad.htm
    Basically, it's the one with the pad "on the side", though sometimes I wish I'd got the one with the pad in the middle as it's a little awkward to use, but hell I'm still happy :-)
    Mike
    You can buy Bluetooth 4.0 related boards here:
    http://www.elecfreaks.com/store/products_new.html
  • Problemchild
    Problemchild over 11 years ago in reply to e14 Contributor
    I've found that almost any BT dongle has worked on the RPI not that I have any funny makes in my pot of gear:)
    CPC/E14 have several different compatible makes available. The 2 years since this thread started as improved things tremendously!
  • siliceo
    siliceo over 9 years ago in reply to dharr19
    @David_Harrison,
    I know it's been a while since this post, but for the sake of anyone else asking the same question, what I found today (11/16/2016) is the "little stubby thing" is an "Importer520 Bluetooth 4.0 USB Micro Adapter (CSR 8510 Chipset)" -- available at Amazon for under $10.
    Cheers!
