Raspberry Pi Forum PiFace Relay  Motor Control Extra
  • Replies 19 replies
  • Subscribers 707 subscribers
  • Views 2915 views
  • raspberry_pi_b_plus12vmotor
  • piface
I want use this board and PiFace Relay+ to drive a 12 V DC motor, is that possible ?
    mcb1 over 11 years ago
    I presume you meant this (for future adding the link means we can see what you are referring to)
    PiFace Relay plus for Raspberry Pi Model B plus
    As long as your 12v motor doesn't exceed 1A
    The alternative for switching two relays is
    http://www.element14.com/community/docs/DOC-69001
    Despite the relays stating they are 10A, i suspect the pcb tracks are not sufficent.
    I see that the new plus model soleves the problem of access to the GPIO pins.
    I did this to mine.
    http://www.element14.com/community/roadTestReviews/1452
    e14 Contributor over 11 years ago in reply to mcb1
    Thanks for your reply.I have that concern is because when I check the technical specification on http://www.element14.com/community/docs/DOC-72072/l/getting-started--piface-motor-extra-interface-board-for-raspberry-pi . The motor supply voltage is 0V - 11 V, what does it mean?
    mcb1 over 11 years ago in reply to e14 Contributor
    Oh
    I see this is an addon board to the PiFace.
    It provides an H Bridge and it seems that the maximum voltage is 11v.
    So it will run a 12v motor at less than 12v ... which might not work.
    You haven't stated what the motor current is ...
    mark
    I using a dc motor with 12 V 0.1A-0.3A~
    if that is the case, what motor driver which can be found in element14 would you suggest me to use?
    balearicdynamics over 11 years ago in reply to e14 Contributor
    Why don't use the PiFace motor control new version ? I have never heard of this extra but in the PDF link it seems that is a sort of part completing an old PiFace motor control board.
    Take a look to the specifications of the PiFace – PiFace Digital
    Enrico
    e14 Contributor over 11 years ago in reply to e14 Contributor
    But i find that the piface digital is not integrated with H-Bridge motor controllers for me to program the motor as bidirectional. Correct me if I am wrong.Thanks.
    It seems a very expensive way to control a motor.
    Adafruit has an example here.
    https://learn.adafruit.com/adafruit-raspberry-pi-lesson-9-controlling-a-dc-motor/overview
    They have a board
    https://www.adafruit.com/products/2348
    It seems that element14 are not stocking this one.
    Sorry but I focused the attention on the relays. In my vision the h-bridges can be added directly to the GPIO (a lot of pin remain free) or - to be tested , to the digital I/O of the board. Remain true what mcb1 says (below) about a less expensive solution.
    Enrico
    balearicdynamics over 11 years ago in reply to mcb1
    In past to control the DC motors of my primitive first mill machine I have developed a ULM2004 based h-bridges board. Sure it was supporting up to 3 A and 12 V DCC. If you need I can send you the design scheme or the project or make a PCB.
    Mark, I choosen ULN 2004 / 2003 for DC motors control just for the very low price of these IC. AFAIK the adafruit board is jul 22$, anyway not so cheap respect what it can do. In the perfect Adafruit / sparkfun style image
    Enrico
