Raspberry Pi Forum Wiring a motor to the RPi?
  • Replies 63 replies
  • Subscribers 710 subscribers
  • Views 10332 views
  • help
  • rc
  • pi
  • control
  • please
  • motor
  • raspberr
wallarug
wallarug over 14 years ago
What do I need?
I am told that I need some transitors.  I have a 12v powerpack and 2 x12v motors.  How do I set this up so that I don't blow-up the RPi and that I can control the motors through the GPIO?
I have a gertboard on the way but I would like to see if I can do it without it first.
I have little knowlegde about transitors and electronics but I do know how to build circuits.
  • wallarug
    wallarug over 13 years ago in reply to e14 Contributor
    Thanks Ken.  Great work.  I will test later
    What about the double H-Bridge chip in the earlier post?
    e14 Contributor over 13 years ago in reply to wallarug
    The schematic is for TI's L293D chip, which was posted above in a link from Adafruit.
    It is a dual H-Bridge motor driver.
    The E on the end of the part number is from the Eagle part library, but the pinout is the same.
  • wallarug
    Thanks for informing this of that fact.
  • wallarug
    How can I get PWM working on the motors? Can you please give me instructions on software and/or extra hardware required (input device)  for PWM to work.
    Thanks for all your help so far.
    Hardware such as what gert used in his video (the slider at 3:40):
    michaelkellett over 13 years ago in reply to e14 Contributor
    @Ken
    There is an error in this diagram: pin 8 should be connected to 12V and pin 16 to 5V - why - because pin 16 is what ST (the chip maker) calls Vss and is the logic supply voltage and pin 8 is Vs which is the motor supply voltage.
    This circuit would be improved by changing the 100R resistors for a higher value, 2k2 would be fine and would reduce the current in the 2N2222A2N2222A transitors from 50mA to 2.3mA while still being able to pull the L293 inputs high. (They need 100uA max).
    Michael Kellett
  • wallarug
    wallarug over 13 years ago in reply to michaelkellett
    Just an update on what I am going to use to built this circuit:
    2 x 12v motors
    1 x 12v power supply (batery pack)
    1 x L293D (double H-bridge chip)     http://www.adafruit.com/datasheets/l293d.pdf  < Datasheet
    1 x ULN2003 (Darlington Transistor - instead of normal transistors) http://www.jaycar.com.au/products_uploaded/ZK8855.pdf  < Datasheet
    Whatever restiors anyone suggests (I will buy when necessary)
    Headers & PCB
    1 x Raspberry Pi
    Can someone let me know if anything else is required.
  • wallarug
    2 x 12v motors
    Headers & PCB
    1 x Raspberry Pi
    I have just bought some more stuff that I though you should know:
    4 x 100ohm 1 Watt 5% Carbon Film Resistor - Pk. 2
    4 x 680ohm 1 Watt 5% Carbon Film Resistor - Pk. 2
    4 x 2K2ohm 1 Watt 5% Carbon Film Resistor - Pk. 2
    1 x ULN2003 Darlington transistor array IC
    Any of this can be used in the circuit.  If anything else is required, let me know.
    Sorry, I have been out of town most of the week.
    I have an update to the schematic to correct errors caught by Michael Kellet.
    He made me think about small amount of current heeded by the L239D chip.
    Another way to think of it is a high impeadance input.  So we don't need
    a lot of current gain in the transistor.
    While darlingtons are high current gain.
    The current on the chip input/transistor output will be set low by the high chip input impeadance.
    When you use a transistor as a switch, you set the Ib * Hfe to be larger than where the ciruit
    will operate in order for the transistor to alternate between cut off and saturation.
    So I upped the resistor values but did not set Ib * Hfe to match the current needed by the
    chip but rather to provide 10 or more times as much.
    The real current will by limited by the chip input impeadance and you have a low voltage
    dropped across R4/R5/R6.
    Ib is the transistor base current.
    Hfe is the transistor current gain.
    By lowering the base current, we ask the Raspberry Pi to provide less current.
    I drove motors with an Arduino.  It runs on 5 Volts.  It has analog inputs.  It has lots of PWM
    outputs.  It won't run Linux or Python.
    I have not yet tried the one PWM output on the Pi.  I don't know if a PWM driver is ready or not.
    An 8 but micro-controller normally has PWN hardware outputs.
    Software pwm is where you turn the GPIO output off and on and increase the speed
    by having it on a higher percentage of the time.
    I've thought of connecting an Arduino to the PI with 5 Volt serial or I2C and having the
    Arduino do motor control but probably not get to it.
    I have driven stepper motors directly of a GPIO with Darlingtons but without an H bridge chip.
    Any way here is the updated schenmatic in PNG. I am trying to attach the Eagle schematic.
    ken2..zip
  • wallarug
    How would I subsitute in a Darlington Pair into your schematic?  I have a ULN2003 Darlington IC transistor array.  See the datasheet below:  http://www.jaycar.com.au/products_uploaded/ZK8855.pdf
    Also, If I want to run two motors through PWM, then I would have to 'piggy back' off the circiut that is already present.  See My Schematic (experimental) based off yours below.  I think this becasue the raspberry Pi (as far as I know) only supports 1 'connection' of PWM.  Am I correct?
    One other thing, is the 5 volts coming out of the Raspberry Pi or an externatal source?
    I couldn't find an Eagle part model for the darlingtons.
    The seen to have all the bias resistor internally.  You are not connecting them to the motor directly,
    so you don't need external diodes.
    So 5 Volt supply to ULN2003 pin 9.
    Ground to ULN2003 pin 8.
    Rasberry Pi pin 7 to ULN2003 pin 1.
    Rasberry Pi pin 5 to ULN2003 pin 2.
    Rasberry Pi pin 3 to ULN2003 pin 3.
    ULN2003 pin 16 to L293D pin 1.
    ULN2003 pin 15to L293D pin 2.
    ULN2003 pin 14to L293D pin 7.
    You don't need the external resistors.
