Raspberry Pi Forum GPIO output from keyboard
  • Subscribers 705 subscribers
  • Views 1072 views
  • gpio;
  • help
  • robot;
  • raspberry_pi;
  • rpi;
wallarug
wallarug over 14 years ago
Does anyone know how to code a python script that will be able to achieve this WITHOUT pressing enter each time?
I am building a car powered by the RPi and I was wondering if this was achieveable.  Here is what I have so far:
print "The controls are as follows: "
print "w = forward; a = left; s = backwards; d = right "
a = raw_input("Press a key to move the Robot: ")
while a:
    if a.lower() == 'w':
        print "working forward"
    if a.lower() == 'a':
        print "working left"
    if a.lower() == 's':
        print "working backwards"
    if a.lower() == 'd':
        print "working right"
Any Idea how I would Modify this to do what I want?
BTW: I know how to get the GPIOs working but I can't test then in a shell, so I just used print functions/output.
    Console I/O in Python is OS dependent.
    On Posix compliant systems, such as Linux and Unix,
    you would put the terminal in "cbreak" mode,
    http://en.wikipedia.org/wiki/Cbreak_mode
    which doesn't wait for a whole line to be entered.
    Python docs are here:
    http://docs.python.org/library/tty.html
    For fancy uses, see the "curses" library, in cbreak mode.
    http://docs.python.org/howto/curses.html
  • wallarug
    wallarug over 14 years ago in reply to e14 Contributor
    Can I just clarify,
    I am going to be using the Raspberry Pi (Linux).
  • wallarug
    Should I use getch()?  I have done some research and this seems to be the way to go.
    e14 Contributor over 14 years ago in reply to wallarug
    Is getch() available on linux?  I think it's only available
    in the Windows msvcrt library, or in the curses library.
    On linux you will want to set the terminal in "cbreak" mode,
    and then read the character using
       ch = sys.stdin.read(1)
    when you are done, you will probably want to restore the
    terminal to normal mode.
    You can set "cbreak" mode on linux using
       tty.setcbreak(fd[, when])
    as shown here:
    There is an example here:
       http://www.dzone.com/snippets/cross-platform-getch-python
    although it uses "raw" mode instead of "cbreak" mode,
    and doesn't restore the old settings.
    The difference between "raw" mode and "cbreak" mode is that
    control-C works normally in "cbreak" mode, but not in "raw" mode.
    There is an example of restoring the normal tty mode here:
       http://docs.python.org/library/termios.html#module-termios
    Alternately, you can use the curses library:
    import curses
    stdscr = curses.initscr()
    curses.cbreak()
    c = stdscr.getch()
    curses.nocbreak()
    curses.endwin()
  • wallarug
    Thanks for the responce.  I will look into cbreak mode and see if I can get it working on linux. image
