Raspberry Pi Forum Keyboard not mapped correctly?
  • Subscribers 707 subscribers
  • Views 686 views
davewerld
davewerld over 13 years ago
I was hooking up my new Rapsberry Pi and started working on making the wifi connection. I'm noticing that the keyboard isn't quite matching what I am typing. Only on a couple things. Those things are #, @ and ~. For some odd reason, they are found at |, SHIFT ' and SHIFT |. Does anyone know what my problem is?
I did swap out the keyboard and other keyboards act the same. Also, the other keyboards work fine on the other machines.
Dave
  • msilveus
    msilveus over 13 years ago
    Hi Dave,
    For starters make sure your /etc/defaults/locale is set correctly. The distribution comes defaulted to en_GB and the keyboard layout is slightly different. You can use 'sudo raspi-config' to set or whatever else you're comfortable with. Secondly make sure your keyboard is listed here: http://elinux.org/RPi_VerifiedPeripherals
    Mike
  • davewerld
    davewerld over 13 years ago in reply to msilveus
    Well, that seemed easy. It's working now. Sorry for the question. They'll get better.
    Dave
  • msilveus
    msilveus over 13 years ago in reply to davewerld
    The only poor question is the one not asked. I had the same problem earlier and and while poking around realized what the solution might be and it worked for me. I'm sure a lot of owners hit the same problem here on this side of the pond.
    Mike
  • davewerld
    True. It's just seems so obvious once the answer is presented. Thanks again. I may have been typing Shift ' for a while...
    mcb1 over 13 years ago in reply to davewerld
    Its worse when you have two of the same PC's.
    One that was supplied with the project that has a UK keyboard, and another that uses the US version......
    Some keys are in different locations.....
    Some of the distros include the location, etc in a start script...
