Hello i would like to build an communication between my home pc and the Raspberry Pi in my vacation house. Is this possible with Teamviewer ore is there an other possibility?
Do you mean you wish to see the actual desktop of your home PC, on the R-pi screen?
Some conventional ways of achieving this involve VNC or Remote Desktop. However, they would require you to
either have a static IP address (not common in many countries for home users), or to open up ports on your router
and to remember the IP address (which can and will change, so you'd have to make sure to check your
IP address before you leave to go to your vacation home). It could even be possible to devise a method where
the home PC sends you an e-mail with the static address I suppose, depending on how complicated you want to
get : ) I've not tried it for home use (I have not had the need), but I'm
sure there are plenty of resources to show how to do remote viewing using VNC or Remote Desktop (the latter assumes
your home PC is running Windows). I saw this link for rdesktop.
Personally I prefer Remote Desktop (seems faster to me) but VNC works with multiple platforms).
A far easier alternative is to just take a copy of your hard disk's files with you on vacation on a USB stick ; )
But you may have a particular scenario that requires remote viewing.
I would like to view my security camera's remotely.
Take a look at this tutorial on Adafruit for remote desktop capabilities on your RPi
http://learn.adafruit.com/adafruit-raspberry-pi-lesson-7-remote-control-with-vnc
You can always install vnc, if you are using Raspbian.
You can install Teamviewer using Eltechs Exagear. Here is a description how to make it: Run TeamViewer on Raspberry Pi
TeamViewer should be OK. But if you want to try out any alternatives, you may try on premise R-HUB remote support servers.
