Raspberry Pi Forum How do i make a graphical interface (os) for example an MP3 menu
  • Subscribers 706 subscribers
  • Views 568 views
I am just wondering how to make a user interface that I can create my own and apply it in to something that I would use with LCD or any devices I might create. I just want to know what do I need in order to create something like that
thanks you for your time image ! image
  • Nate1616
    Nate1616 over 13 years ago
    What programing software do you plan on using?  For example if your using Visual Studio you would just have to set up some forms with buttons and have code assigned to the buttons.
    e14 Contributor over 13 years ago in reply to Nate1616
    i will be using visual studio c#.  But taht is more like for making windowns application. i want to create my own menu so i can use it on a hardware i want to create. for example in arduino u program the chip and then u assing pins on ur board or commands to able to work. instead i want to use a software to control it.
  • Nate1616
    Nate1616 over 13 years ago in reply to e14 Contributor
    Here is a couple of good links you should check out.  http://hackaday.com/2011/11/30/graphical-programming-with-the-arduino-ide/.  http://blog.minibloq.org/.
