Raspberry Pi Forum HDMI does not work after upgrade.
  • Subscribers 708 subscribers
  • Views 780 views
  • pi
  • upgrade
rbladd
rbladd over 13 years ago
I have two Raspberry pi and recently purchased a Pi Face Digital.  The software for the Pi Face did not seem to be loaded, so I updated and upgraded the Raspin.
After I upgraded and rebooted the HDMI does not work and composit video works but is wierd.  I gave typed HDMI_safe=1 with no change.  I am using the HDMI input on an ETC TV that worked okay.
Any suggestions?
Answered Message was edited by: Robert Ladd
    suggest try downloading the OS again, and do
       apt-get update
       apt-get upgrade
       rpi-update
    one at a time to see which step causes it to fail.
    The last step is the most bleeding edge risky.
  • rbladd
    Got it to work by editting the config.txt file.
  • mgt6910
    mgt6910 over 13 years ago in reply to rbladd
    Now you've got my attention !  What changes did you make ?
  • rbladd
    rbladd over 13 years ago in reply to mgt6910
    At the Raspberry prompt I entered sudo nano /boot/config.txt
    In the file I first uncommented hdmi_safe=1 which sometimes worked
    Then I uncommented hdmi_force_hotplug=1 and that seems to consistantly work
    because somehow the upgrade gave me composit video in a large font.
    After any change use cntlo, then enter to save to config.txt and cntlx to
    exit.
    At the prompt enter sudo reboot the restart with the new changes.
    good luck
    Message was edited by: Robert Ladd Problem solved
  • wallarug
    wallarug over 13 years ago in reply to rbladd
    For fixing the composite out use the following instructions:
    http://www.element14.com/community/thread/18205?tstart=0
    Otherwise, if this is solved.  Mark as so please.
    my config has only the following "active" lines in it (the rest are comented out) when i only had the "framebuffer_" values i had issues with the display looking "odd" this may be what your seeing. the HDMI mode forces the VGA to work corectly, i did notice however that with certian distributions these settings are not needed as there default startups contained this information outside of the config file.
    framebuffer_width=1024
    framebuffer_height=768
    console-width=1024
    console-height=768
    # uncomment to force a specific HDMI mode (this will force VGA)
    hdmi_group=1
    hdmi_mode=16
