Raspberry Pi Forum Total newby frustration with DiskImager
  • Subscribers 706 subscribers
  • Views 442 views
I first was having trouble, over several days, with verifying the checksum.  Then I realized that the instruction was not exactly correct.  The checksum is applied to the zip file not the image (img) file.
Now that I have a verified good copy of the zip file for the newest Wheezy Version (13-2-9) and the expanded img file, I inserted my SD card into an USB port. It was recognized as device H:
So I started Win32DiskImager-V.07.exe, and when the very long, scary, no-action period ended, a text box appeared wanting to know what img file I wanted to install.  I successfully pointed to that.  Next to the img file name it wanted to know on what device I wanted to install.  I had no choice - it wanted to install on my backup drive, K:.  Would not give me any other choices but K:.  I tried repeating that again, same thing.
My question - What am I doing wrong now?  Was there supposed to be any other preparation to the SD card (a 4G version) like formatting?
Any advice would be appreciated.
Chuck
    mcb1 over 13 years ago
    IS this related to your Pi questions you had in another post.
    I think you'll find there is a bug in the later version.
    https://bugs.launchpad.net/win32-image-writer/+bug/1118217
    I think the earlier versions are here.
    https://code.launchpad.net/win32-image-writer
    e14 Contributor over 13 years ago in reply to mcb1
    Actually, I got it to work!  Turns out that my Win7x64 system saw the card reader but did not see the card.  I took it out and firmly replaced it.  Bingo.  Took about 40m to write to the card (Wheezy) at about 0.8MB/s average.  But the Win32DiskManager did what it was supposed to.  I will try my RPi tomorrow.
    So people, maybe just wiggling your card in place will work for this image writing.  There is a warning that you should not insert or remove the card from the RPI unless the power is off.
    My solution was simple.
    Chuck
    mcb1 over 13 years ago in reply to e14 Contributor
    Chuck
    Great it works.
    Seems there are a few isues with cards not connecting correctly.
    Can you please look towards the bottom and tag this as answered.
    I even saw that it was possible to mark your own post as answered ...
