Raspberry Pi Forum Where did my pictures go?
  • Subscribers 706 subscribers
  • Views 719 views
spidermonkey12w
spidermonkey12w over 13 years ago
I finally got my Pi upgraded and was able to get the camera working. Now I'm new to the Pi and to programming so a lot of what it can do at this point is lost on me, but I'm getting better. Can someone please help me locate the pcitures that I've taken using the Pi camera? Is there a command I have to give the Pi to bring them up for me or are they hidden somewhere in the desktop that maybe I'm just not seeing. Thank all for your help.
    This is some what of a loaded question.  I will try and give you command here along the way.  However, the first thing we need to know is what software you are using to capture the images.video.
  • spidermonkey12w
    spidermonkey12w over 13 years ago in reply to e14 Contributor
    I have the latest version of Wheezy, which I downloaded from www.raspberrypi.org
    Hi Jason,
    That is worth knowing
    But I think that what Bradley is asking, and what we need to know to help you is this: what command or program did you run or otherwise use to take these picures?
    Can you detail the steps to take a picture?
  • spidermonkey12w
    Oh sorry about that. I entered:
    and
    raspistill -o testimage1.jpg         <-------- that was just because I took a second photo.
    e14 Contributor over 13 years ago in reply to spidermonkey12w
    no problem.
    I've never used raspistill, but if it has created images this should find them.
    Can you get to a terminal (e.g. using the LXTerminal desktop icon), and at the command line enter this:
         find / -name "testimage*" -print 2>/dev/null
    That should search absolutely everywhere for files starting with "testimage".   The bit on the end is simply to discard error messages (because this command will try to look in places you're not allowed to see).
    It should only take a handful of seconds, at most to run, and will print out the filenames, if any.
    also. to find files,,, if you did StartX to bring up the Rasp-pi GUI... go to bottom left and click on "file manager"  ,, that should show u files
