Raspberry Pi Forum Windows C/C++ Cross Compilation Toolchain for Raspberry Pi
  • Replies 21 replies
  • Subscribers 711 subscribers
  • Views 5750 views
  • research
  • raspberry
  • raspberrypi
Hi everyone, I am trying to compile my C/C++ project from Windows 7 machine, and use Eclipse Juno GDB to remote debug the application on RPi. So far I do not have any luck on getting the Toolchains to work correctly. Appreciate if you can share any gnu ARM toolchain for Windows 7. Alternatively, you may suggest me of any good C/C++ development solution for RPi, which will work right-out-of-the-box. Thank you.
Cheers,
Bryan
  • guzunty
    guzunty over 13 years ago in reply to mcb1
    Mark Beckett wrote:
    Wouldn't real men do it with punch tape...?
    Real men do it with neons and switches. Sheesh, you kids and your fancy EMUI's*
    Seriously, the Code Sourcery toolchain does the trick. Eclipse is designed to support cross compilers and remote debugging. I have configured it to do so for several devices. I have not so far had a reason to do so for the Pi but I'm sure it will be as straightforward as the others.
    I have read that Eclipse can run directly on the Pi, but having run the Arduino IDE on the Pi I would suggest you don't even try Eclipse.
    Derek
    * Electro-Mechanical User Interface
  • mconners
    mconners over 13 years ago in reply to guzunty
    Yes, you can do it with eclipse, but not with the toolchain producing the error messages above, that is clearly the arm-none-eabi, the one he will want to get is found here
    http://www.mentor.com/embedded-software/sourcery-tools/sourcery-codebench/editions/lite-edition/request?id=478dff82-62bc-44b2-afe2-4684d83b19b9&downloadlite=scblite2012&fmpath=/embedded-software/sourcery-tools/sourcery-codebench/editions/lite-edition/form
    that is
    Sourcery CodeBench Lite Edition for ARM GNU/Linux
    as I said I have done it with eclipse on linux I assume the same is available for windows. Also
    https://sourcery.mentor.com/sgpp/lite/arm/portal/kbentry34
    tells why there are 3 different arm-*-eabi toolchains.
    Mike
  • mconners
    mconners over 13 years ago in reply to mconners
    Also if you look at the error messgaes spit out above it compiled fine. The issue was in the linking. It couldn't find the libraries it needed to do the simple "printf()"
    that he probably calls in his program.
    Well, they say the pi is a tool for education, this guy will learn alot by getting eclipse for windows to compile an executable for the pi.
    All good.
    Mike
  • mconners
    mconners over 13 years ago in reply to mcb1
    Yes
  • mconners
    Honestly, I've never used punch tape professionally. During my training we had to punch a diagnostic routine and I learned how to fix a punch and reader, but I never had to use one IRL.
    Mike
    e14 Contributor over 13 years ago in reply to mconners
    Bringing this back on topic (and back into the 21st century...) we've now cracked it!  We can now develop code on a PC in an Eclipse-based environment and then remotely debug it on the PC, with the application running on the Pi.  We can run to main(), single-step, watch variables, all that good stuff :-)
    Top-secret how we did it for now image but we'll be putting up a guide how to do it in the next few days...
    Cheers
    Richard
    Hitex UK Ltd
    Hi Richard,
      Nice to hear that. Hopefully we can include all kinds of libraries as well, include libc, opengl, libbcm, etc.
      Hope to hear to good news from you.
    Cheers,
    Bryan
  • bbolo1
    bbolo1 over 13 years ago in reply to e14 Contributor
    HI Richard,
    Great idea. Would we need anything else other than the GDB server on the RPI?
    Right now, this is how I am developing my apps.
    App compilation and debugging are being done onto the PC side. After compiling the app with debug symbols, I need to copy the PC cross-compiled executable onto the RPI and run it using the GDB server.
    On the PC side, the GDB (coming with the cross-compile package) will connect to the RPI GDB server through ethernet. Afterwards, happy debugging.
    Is this setup similar to what are you going to present in the guide?
    Cheers,
    Bogdan
    Hi Bryan, Bogdan,
    It's not actually me that's cracked it, it's a colleague of mine at Hitex UK.  We are making it so that you can use the Community Edition of ARM's DS-5 toolset with the RPi and it does indeed go in through GDB.  Hopefully we'll have something to publish soon!
    Cheers
    Richard
    You can find details of the RPi Windows Eclipse C/C++ cross compiler development/debug environment here....
    http://bit.ly/HBEay3
    It works for me!
    Mike Beach
    Hitex UK
