Raspberry Pi Forum Windows C/C++ Cross Compilation Toolchain for Raspberry Pi
  • Replies 21 replies
  • Subscribers 711 subscribers
  • Views 5746 views
  • research
  • raspberry
  • raspberrypi
Hi everyone, I am trying to compile my C/C++ project from Windows 7 machine, and use Eclipse Juno GDB to remote debug the application on RPi. So far I do not have any luck on getting the Toolchains to work correctly. Appreciate if you can share any gnu ARM toolchain for Windows 7. Alternatively, you may suggest me of any good C/C++ development solution for RPi, which will work right-out-of-the-box. Thank you.
Cheers,
Bryan
  • davidcozens
    davidcozens over 10 years ago
    I know this is years after the event, but I've just hit the same problem of getting a professional C/C++ cross development environment to work for the RPi. I found that I managed to get a very good (free) solution by using a pre-built cross compiler and eclipse mars CDT. Step by step setup details are on my blog at David's Software Blog: Cross development using eclipse and GCC for the RPi.
