Raspberry Pi Forum Piface install script question
  • Subscribers 706 subscribers
  • Views 673 views
Hi all
Trying to install piface emulator and now getting this message image
pi@raspberrypi ~ $ piface/scripts/piface-emulator
Traceback (most recent call last):
  File "piface/scripts/piface-emulator", line 5, in <module>
    emu.init()
AttributeError: 'module' object has no attribute 'init'
have been able to once get the emulator "up" on screen but said it could not find the piface (which is firmly plugged in )
scratching my head on what to do next
cannot find any info in discussions - do I need to do a full reinstall ?
I am a newbie so please be gentle image
  • videogame95
    videogame95 over 12 years ago
    download new piface raspianwheel cobined in has it installed
    or type interminal window #blacklist spi-bcm2708
    type in sudo raspi-config
    type sudo reboot
    or
    wget -O - http://pi.cs..man.ac.uk/download/install.txt | bash
    capital O above
    sudo reboot
    e14 Contributor over 12 years ago in reply to videogame95
    Thank you I will give that a go on the week end and let you know how it goes
    Apologies for crashing your thread. I’m also going through the painful process in getting my PiFace working. When I enter your suggested commands I get the following.
    type in sudo raspi-config – takes me to the an configuration/setup screen. Not sure what to do here?
    piface/scripts/piface-emulator – I get the following message:- bash: piface/scripts/piface-emulator: No such file or directory
    wget -O - http://pi.cs..man.ac.uk/download/install.txt | bash  -   I get the following message:- wget: missing URL
    Usage: wget [OPTIO]… [URL]…
    Try ‘wget –help’ for more options
    Any suggestions will be welcomed.
    Andre
    still no go :-(
    Hi Joe,
    After a long struggle I got mine to work. However I started with a clean SD card and loaded NOOBs1.3 latest operating system. Must say its very cool the guys did a great job. image I then got BMXC working without any pain.
    Regardingt he PiFace. I used a combinations of scripts and commands to get it working. One of the scripts did not work and I type the commands in manually, line by line. I'm happy to email you my list of instructions that I used.
    Regards
    Andre
    ps now for the camera ....
