Raspberry Pi Forum conection
  • Replies 8 replies
  • Subscribers 708 subscribers
  • Views 981 views
conection
When I connect a Pi to a monitor using HDMI to VGA cable I get no output
  • gadget.iom
    gadget.iom over 12 years ago
    Apologies for stating the obvious, But have you tested the monitor on another device and/or the pi on another display?
  • element14jamie
    element14jamie over 12 years ago
    Hello Dave,
    Welcome to the community, I will move this to the Raspberry Pi area, as it fits your question better.
    Thank you,
    Jamie
  • wallarug
    wallarug over 12 years ago in reply to element14jamie
    They do not work...
    You are out of luck.
    http://elinux.org/RPi_VerifiedPeripherals#HDMI-.3EVGA_Cables
  • Bobalong
    Bobalong over 12 years ago
    If I turn on my Pi when the attached TV is off, I get nothing on the TV when it is turned on.  This suggests that the Pi needs to sense the TV.
    It may be that your  converter is not sensed.
    Check out /boot/config.txt for a way to force HDMI output.
    HTH
    Jim
  • wallarug
    wallarug over 12 years ago in reply to Bobalong
    James.  These adapters just don't work (according to the link posted above).
    e14 Contributor over 12 years ago in reply to wallarug
    I
  • gadget.iom
    I have a Raspberry Pi HDMI to VGA adaptor. Can you give some details about what kind of cable/adaptor you are trying to use?
    I have used a VGA converter and it works.
    Does the raspberry output to HDMI? or Analog? Are you just starting with the NOOBS files? Did you configure it to use a different video output?
    http://www.penguintutor.com/news/raspberrypi/hdmi2vga
    Discusses how to force the output
    if your are starting with NOOBS, the instuctions tell you to press a number key to change the output, so you could try pressing 1 or 2.
    Options: 1-HDMI preferred mode, 2-HDMI safe mode, 3-composite PAL mode, 4-composite NTSC mode
    Are you sure the Raspberry is getting enough power, so is booting up?
