Raspberry Pi Forum My lovely RaspberryPi is dead...
  • Replies 57 replies
  • Subscribers 716 subscribers
  • Views 7743 views
  • no_tv_image
  • not
  • booting
I was so looking forward to it and I was pleasantly surprised how the  RaspBMC from the NOOBS package worked, I have even bought a wireless  keyboard for it ( http://www.totalhtpc.com/logitech-k400r-wireless-touch-keyboard-review/ ) but...
The problem started about a week ago, when I had to unplug  everything to get the image going, as it was all stuck. Several reboots  and it started working again but all that unplugging and plugging it  back again - maybe it was the electricity somehow damaging some of the  HDMI/composite circuitry?
I can see  that it is powered up (there is red light inside) but neither HDMI, not  Composite cables give me any image whatsoever, on the TV.
I  have reformatted and copied the NOOBS files to the SD card, as  described on your pages - but I get no system booting in any way. Not a  flicker of an image on my TV.
The SD card seems OK, as I have dealt with it in my laptop without a problem.
I also tried other OSs, like RaspBMC alone, as well as OpenELEC. Alas, to no avail. The same applies.
I have tried different ports and different cables. Not a squeak.
Therefore, I must conclude it is the HW that is faulty.
Please, instruct me how to return the Pi to you.
A refund is preferable to "repair and return", at this point. No response from "sales" at Fernell, sadly... Just forwarded it to the other email...
In addition, I hope this might help a bit...
I  have read that Pi  might be susceptible to varying voltage/electricity problems. I have a  Belkin safety multiple extension cord, with serious protection against  electricity surges. So, can it still be an electrical mishap?
Or is it simply the power supply issue, as some here have suggested, in which case we would need a really good one, properly advertised here and on sales website...
May  I also suggest a ON/OFF switch, as a good idea, which may go  a certain  way towards preventing this from occurring. I understand that it only  uses very little electricity but I think this is beside the point.  Sometimes my NAS would not go to "Standby" mode after 10 minutes as I  set it up because it seems that RaspBMC could have been queering it?
Not  sure what exactly went wrong but I can see quite clearly that both HW  and SW improvements are possible. I would urge you to contact the patent  holders ASAP, in order to make the Mark III...
Best regards,
gorski
P.S. Anyone with multiple HDMI switches experience? I have this one in my mind: http://www.amazon.it/Ligawo-%C2%AE-switch-attivo-automaticamente/dp/B002I9LH2Q/ref=sr_1_1?ie=UTF8&qid=1382270091&sr=8-1&keywords=ligawo+5x1
  • iagorubio
    iagorubio over 12 years ago in reply to e14 Contributor
    I saw what you wrote, but you did not even wrote if Farnell was where you bought the Pi.
    It' not my bad reading what made me doubt about what was happening, was your explanation of what happened.
    Anyway supposing you bought your Pi in Farnell, got a return number and sent the Pi - because you did not yet told us if that was what happened - you should take this to customer support.
    Farnell is a big and serious company, you have many ways to ask for support.
    If you took an RMA number and sent your device you can get support here Suggest Feedback / Report a problem | Farnell UK
    If you still have no response you can use the phones here Technical Support and Data Services | Farnell UK
    You also have this email to tell them your problem, sales@farnell.co.uk .
    Just don't let it go, if your email contact is not working phone them or use another email.
    What country site did you bought your Pi ?
    May be you can take it to global support in support@farnell.com if you are having problems with a country branch of Farnell.
    e14 Contributor over 12 years ago in reply to iagorubio
    Thank you for all the tips!!! Maybe, eventually, they might answer...
    However, next time you should read a little bit more carefully, starting from the very first post:
    "A refund is preferable to "repair and return", at this point. No response from "sales" at Fernell, sadly... Just forwarded it to the other email..."
    Bought it from the (Fernell, obviously) UK, returned via the courier they sent to pick it up at my address (as I said, all that looked very well, very professional) but then - zip, zilch, nada, nothing, not a sausage... image
    Echhhhhhhhhhh....image
    ...oh, I don't know... how sad is this...?!? I have to bump it, so someone finally notices...
    Apparently, there are people here who are their employees or partners but...
  • rew
    rew over 12 years ago in reply to e14 Contributor
    Call them! sometimes Emails get lost inside big companies.
    e14 Contributor over 12 years ago in reply to rew
    Yeah but who knows how many email from the same person...???
    But you're right, I will have to do that, too...
  • rew
    Oh, in practise it is not "a technical glitch caused your Email (and maybe a few others to be deleted from our inbox", but more likely that person X who handles the inbox forwards it to Y who forwards it to Z who thinks he's just being CCed on some conversation he doesn't have to take part in. But allow them to keep up pretences that it's the "glitch". Your followup emails follow the exact same path.
    Finally, somebody responded... A promise to send a replacement, on a date I requested, as I won't be here in the next few weeks... image
    I will keep you posted... Fingers crossed! image
  • DAFlippers
    DAFlippers over 12 years ago in reply to e14 Contributor
    I have a number of RPis and a while ago one that had been working failed to boot.  When power was applied I got the red LED but no green LED.  I goggled/binged for boot issues and you get these symptoms with faulty SD card or SD card socket.  I then tried pushing the SD card as I applied power and sometimes I got a green LED.  So as I had done a lot of work on this RPi (one of the early ones) and it was near enough out of warranty I set about adjusting the contact fingers.  Pop the SD card back in and Bob's your uncle it all worked.
    So if anyone gets the not booting problem and the SD card can be read in another device try pushing the SD card onto the contacts and if you get a green light it's the SD card socket.
    David
    e14 Contributor over 12 years ago in reply to DAFlippers
    Thanx, David!
    Indeed, I managed to reprogramme the SD card but I have not messed with the contacts...
    I hope I don't get the chance of finding out if this is a common problem, though... image
    Cheers!
    Thats why I bought case of PIs. I dedicate each pi to fixed uses.
    And keep one to lay with.
    My ham radio dstar nodes, each have a for each wifi address( hot spot, home work)
    Jus mark the cases.
    Sent from my iPad
