Raspberry Pi Forum PiFace HTTP Interface
  • Subscribers 706 subscribers
  • Views 597 views
  • python
  • pi
  • web
  • raspberrypi
  • http
  • piface
I have a Raspberry Pi running the latest version of Raspbian with a PiFace connected to it. I can run the PiFace emulator and Python scripts against the PiFace just fine. Everything from a command prompt works. This is great, but my goal is to be able to remotely control the PiFace from a web page. I followed the directions in the PiFace Google Docs documentation page here:
https://drive.google.com/folderview?id=0B-UAZ9CyJCLGQjJ3RDlqa2pqaDg#
After some troubleshooting and tweaking later (there's one extra httpi directory deep) I can access the initial web page, but the web based interface keeps throwing up this error:
Error: can't open device: /dev/spidev0.0
It appears to be a permission issue, but I've tried everything I can think of to no avail. I've spent the past two weeks on this problem and it's really frustrating. My original goal was to automate my garage door. I've got all the hardware working, it's just a problem of this web interface. I just need a working web interface so I can see how this is all supposed to work so I can tweak it to my needs. Sadly I'm not smart enough to build this from scratch. Can anyone point me in the right direction to fix this error? Is there a better way to make a web interface connection to the PiFace so I can run my garage door? Any help would be appreciated.
  • kristi@njeppesen.dk
    kristi@njeppesen.dk over 12 years ago
    I had the same problem.
    Check that you have the spidev0.0 and spidev0.1 in directory /dev. If not run the raspi-config:
    $sudo raspi-config
    Then navigate to "Advanced Options" select SPI and YES.
    See: https://github.com/piface/pifacecommon
    It appears that you are using an outdated version of the PiFace software. Check out github.com/piface/pifacedigitalio.
    There is a link to the new documentation in the readme file. The Web interface is in the examples directory. If you run the web interface it should provide instructions on how to use it in the terminal.
        python3 simplewebcontrol.py
        Starting simple PiFace web control at:
                http://192.168.1.10:1234
        Change the output_port with:
                http://192.168.1.10:1234?output_port=0xAA
    Hope that helps.
