Raspberry Pi Forum idle and memory leaks
  • Subscribers 695 subscribers
  • Views 808 views
I notice if I leave a script running for a couple of days in the python ide that the pi slowly runs out of memory, yet the same script running not in the idle shell shows no sign of memory leakage at all . why is this ? I'm using the noobs dist python 2.7 and have checked for updates. quitting idle releases the memory.
its not problem I'm just curious
  • johnbeetem
    johnbeetem over 12 years ago
    Sounds like memory fragmentation.  When the script is running by itself, its dynamic memory use is simple and the script is able to reuse memory that's been deallocated.  With the IDE running, the dynamic memory behavior is more complex and maybe the IDE and script are interfering with each other's ability to reuse memory.
    This is just a hypothesis based on no knowledge of how Python does dynamic memory.
  • iagorubio
    iagorubio over 12 years ago
    It seems that python < 2.5 have indeed memory leaks in idle http://pythonhosted.org/Pympler/tutorials/muppy_tutorial.html but 2.7 should not have them.
    Have you tried to manually invoke the garbage collector on memory intensive methods ?
    You - may be - can pick what is causing it just adding a "gc.collect()" - you need to "import gc" of course - on those methods where the timing is not critical but have created many or big objects in memory.
    Former Member over 12 years ago in reply to iagorubio
    thanks for that iago  , I have added gc.collect() to my script . I will leave it run for a day and let you know if it makes any difference
    Former Member over 12 years ago in reply to Former Member
    gc.collect() reduced the memory leak but it has not stopped it entirely  , still looses 1mb / hour .
    I guess that idle is just not the environment to run long term scriptrs
