Raspberry Pi Forum Instructions for compiling the wolfson audio card kernel drivers and supported use cases
  • Replies 56 replies
  • Subscribers 708 subscribers
  • Views 15128 views
  • wolfson
  • audio
  • drivers
  • kernel
  • raspeberry_pi_accessories
  • card
Hi Guys,
Attached are some instructions for compiling the wolfson audio card kernel drivers into Raspbian and get the software up and running from a Command Line Interface.
Please post back here if you find any issues with getting this to work.
Andy
wolfson_drivers.tar.gz
imageBuilding the Wolfson Audio drivers into the kernel on the Raspberry Pi.pdf
  • superpat
    superpat over 12 years ago
    So fast!!!!!!!!!!!!!!!!
    Many thanks Andy...   I will build a new Raspbian  card, once the current Wolfson audio image has completed
    Unfortunately,  the first Wolson  image I made refused to boot, I am dd'ing it a second time  at the moment, Its a slow job dd'ing 8GB images! It's about 60% done. I will hang on till the end and try it again, before I try  a vanilla raspbian.
    regards
    Patrick
  • superpat
    superpat over 12 years ago in reply to superpat
    Before  I dd'd the  second attempt at a Wolfson image to my 8GB sd card, I completely erased the card.  This time it copied the  image properly.  (3 partitions instead of only two last time).
    I would advise anyone  using the Wolfson image on an 8GB sdcard, to zero the entire card before you start.
    I can ssh into Wolfson Audio  image,  will install  the Audio  card and see what I can see.
    regards
    P
    have you an functional img, for raspberry,?  also do you know if this Wolfson kernel is compatible with WM8731 chipset , ?  regards
  • bantammenace
    bantammenace over 12 years ago in reply to superpat
    I've followed the instructions as far as 7.
    The fetch appeared to work fine but then  git checkout rpi-3.10.y says that rpi-3.10.y did not match any file(s) known to git.
    Any idea where I am going wrong ?
    Thanks in advance.
  • lleibovici
    lleibovici over 12 years ago
    Didn't quite work for me. I found the Image file in ./arch/arm/boot/Image not ./arch/kernel/boot/Image /boot/kernel.img
    Leo
  • superpat
    Hi Andy,
    Just tried to patch kernel following your instructions.
    Patch number 16 fails to apply under git am with the following error:-
    Applying: ASoC: arizona: Disable AIF TX/RX before configuring it
    Patch is empty.  Was it split wrong?
    I have has a look at the mail for patch 16 and compared it wwith some pf the preceding successfull patches and I am bug****ed if I can see why git am thinks this patch is bad.
    Your advice will be gratefully appreciated!
    regards
    Patrick
    e14 Contributor over 12 years ago in reply to superpat
    The message "Patch is empty. Was it split wrong?" is actually from when git tries to apply the 17th file - gpl-2.0.txt - as a patch.
    If you change the command to "git am -3 /home/pi/rpi_wlf_3.10_beta/*.patch" you don't get the error message.
    Ragnar
  • superpat
    superpat over 12 years ago in reply to e14 Contributor
    Hi
    Thanks for the explanation,,,,  I was going mad trying to find a problem with patch 16.
    cheers
    Patrick
  • soundcamp
    soundcamp over 12 years ago
    Thanks very much, Andy and all
    We got to here, all seeming as expected; then got the following:
    ~/kernel_source $ git am -3 /home/pi/rpi_wlf_3.10_beta/*
    /usr/lib/git-core/git-am: 203: /usr/lib/git-core/git-am: cannot open /home/pi/rpi_wlf_3.10_beta/*: No such file
    Following Ragnar's related suggestion, we also tried:
    ~/kernel_source $ git am -3 /home/pi/rpi_wlf_3.10_beta/*.patch
    /usr/lib/git-core/git-am: 203: /usr/lib/git-core/git-am: cannot open /home/pi/rpi_wlf_3.10_beta/*.patch: No such file
    Now we're stuck.
    We'd be grateful for any ideas.
    Thank you
    Grant
    e14 Contributor over 12 years ago in reply to soundcamp
    It looks like the patch files haven't been extracted into the /home/pi directory. Step 4 in the instructions.
    What does the command
    ls -la /home/pi
    return?
    Ragnar
