Raspberry Pi Forum Powering Off
  • Replies 13 replies
  • Subscribers 704 subscribers
  • Views 1789 views
  • troubleshooting
  • raspberry
  • pi
  • raspberrypi
  • shutdown
  • powering
Powering Off
Help!!!! I have my pi up and running, but when it came to power off i thought it would be like a regular computer in which i selected the shut down option. now my pi will not turn on. how can i fix this?
  • tabarus12
    tabarus12 over 12 years ago in reply to e14 Contributor
    The SD slot has a switch on the end of the slot so check the SD is all the way in and not wright protected and then plug the power.
    If your card is a sandisk card the problem might be on the card, those cards are crappy I had this same problem with a sandisk card that I was using for a digital canon camera and had to replace it, if nothing works I recommend you change the card and burn the OS on it.
    Good luck its a lot of fun when you get it working.
  • gdstew
    gdstew over 12 years ago in reply to e14 Contributor
    If you are already on the command line (text only screen), just type in the command as shown. If you are in the windowed (graphical) user interface, log out, which should bring
    you to the command line where you can then enter the command.
    e14 Contributor over 12 years ago in reply to tabarus12
    Thank you, i am sure it is. just to get it up and running is a little drawback. its a learning experience nonetheless.
