Raspberry Pi Forum A new smaller Pi microcontroller
  • Replies 14 replies
  • Subscribers 678 subscribers
  • Views 1430 views
  • computer
  • micro
  • rpi
wallarug
wallarug over 11 years ago
Link:  https://www.indiegogo.com/projects/vocore-a-coin-sized-linux-computer-with-wifi#activity
I found this project today and thought it would interest the community.
It is much smaller than the RPi and it includes WiFi.
Let me know what you guys think about it.
  • wallarug
    More information
    VoCore is a coin-sized Linux computer with wifi. It is also able to work as a full functional router. It runs OpenWrt on top of Linux. It contains 32MB SDRAM, 8MB SPI Flash and using RT5350(360MHz MIPS) as its heart. It provides many interfaces such as 10/100M Ethernet, USB, UART, I2C, I2S, PCM, JTAG and over 20 GPIOs but its size is less than one square inch(25mm x 25mm).
    shabaz over 11 years ago
    It runs Linux, but not all the applications that can run on an RPI. So it won't replace an RPI. It's a very cut-down platform, but great for some projects. These small modules are quite common, another example is 'carambola 2' which is a bit cheaper, a bit larger though, more I/O, less memory but a bit faster clock speed, and is shipping today.
  • tabarus12
    tabarus12 over 11 years ago
    These platforms are awesome for house automation, small and powerful.
    Ill have to get one of those for my home project.
  • rew
    rew over 11 years ago in reply to tabarus12
    But remember... They are not as "comfortable" as a raspberry pi: On a raspberry pi, you can run most normal Linux commands and distributions because you have a "normal" amount of memory. The VOCORE has only 32Mb, which means that things are a bit cramped. But as an embedded Linux machine, doing wifi stuff and maybe a few GPIO things, it is a great platform.
  • Problemchild
    Problemchild over 11 years ago in reply to shabaz
    Hi there Shabaz, yes you are right, this module joins a cast of certainly dozens of modules which have very similar specifications the Carambola2 been only one of them. I have used several of the no name made in china Linux modules and most are absolutely great at that £10 per module price point or about double for an experimenters board supplied.
    No need for another Kickstarter to make these modules they exist today and are available every day of the week on Ebay.
    I would suggest to any one wanting to experiment with these modules today get one of these
    http://www.bypic.byvac.com/index.php/BV503
    Which has you can see has one of these modules a PSU+ pic32 board SDCARD and the outputs to dirve 2x 8 relay boards and an 1602LCD I believe ...Whoopee image
  • Problemchild
    Problemchild over 11 years ago in reply to rew
    Agreed these aren't "'PIs" at all just Linux microcontrollers. Obviously if he didn't call them Pi's no one would be interested in the blog post.  Pi this and Pi the other image
  • johnbeetem
    johnbeetem over 11 years ago in reply to rew
    I first used Unix on a PDP-11/45 with 256KB of memory (yes, K as in Kibble).  It was a time-sharing system, with multiple terminals.  It really only dragged if several people tried to compile at the same time, or worse, run the Ingres database.
    So, yeah, you can do quite a bit with 32 MB, especially with no GUI.
  • Problemchild
    Problemchild over 11 years ago in reply to johnbeetem
    So basically you are saying that we can run a Nuclear Power station on one of these modules as long as we use an old Wyse Terminal and avoid the Zork Text adventure image
  • johnbeetem
    johnbeetem over 11 years ago in reply to Problemchild
    Très amusant.  Should I add that the PDP-11/45 cycle time was a lot slower than 360 MHz?  image
  • Problemchild
    My experience starts with the VAXen really do you have any PDPs hanging around ... I do have a PDP8 clone kit but that's not the same image
