Raspberry Pi Forum Raspberry Pi 2 First Time Setup No Video Signal EMERGENCY (Help!)
  • Subscribers 707 subscribers
  • Views 877 views
  • down
  • signal
  • noobs
  • help
  • frontpage
  • emergency
  • raspberrypi
  • abort
  • rca
  • screen
  • shut
  • no
RovertScott
RovertScott over 11 years ago
I recently received my Raspberry Pi 2 with NOOBS pre-installed on the SD.
The instruction booklet that came with it sated that an RCA or HDMI cable could be used upon startup, so I hooked it up to an old CRT TV from the 80s.
I thought that NOOBS would detect the RCA upon first time startup, before installing Raspbian, but to my horror it did not.
Only now do I read that I needed to have pressed #4 within a 10 second window.
Now unable to reach a wall mounted HDMI screen without unplugging my RPi, I do not know what to do!
...I have no Screen and I must Scream!
Is there an emergency shutdown procedure or something?
  • clem57
    clem57 over 11 years ago
    Just unplug since you cannot fix for now.
    Firstly CRT's cannot be detected and so software guesses what can be supported which can be wrong too often. Can I suggest a different route? Try http://www.berryterminal.com/doku.php/berryboot and select version for Raspberry Pi 2. I have used for HDNMI and find it easier than NOOBS. You need to connect the Raspberry Pi 2 with an ethernet cable or a WiPi at least.
    C
  • RovertScott
    Well, I feel completely stupid... I looked up online and discovered that the 3.5mm jack is wired wrong for a standard RCA TRS plug.
  • clem57
    clem57 over 11 years ago in reply to clem57
    - if you would like to do a headless installation append to cmdline.txt (on the same line as the other options):
    vncinstall ipv4=192.168.88.88/255.255.255.0/192.168.88.1 (IP/netmask/gateway)
    The above must be changed to fit your router configuration.
    C
  • clem57
    clem57 over 11 years ago in reply to RovertScott
    You are not the first and will not be the last.
    C
  • gadget.iom
    gadget.iom over 11 years ago in reply to RovertScott
    Don't feel stupid, you certainly are not alone. image
