Raspberry Pi Forum Solar Powered Pi?
  • Subscribers 676 subscribers
  • Views 388 views
Solar Powered Pi?
Hello!  I am planning to build a pi project, but far from a power outlet.  I was wondering if you could use solar panels as a charger for batteries.  If so, how?
    I found this website with a tutorial. Also if you plan on adding extra part (motors etc) then you may need more power
    http://www.instructables.com/id/Solar-Powered-Raspberry-Pi/
    Former Member over 11 years ago in reply to Former Member
    Thank you!  Do you know what voltage solar panel to use?  Would it just be 12V?
    I think that you would charge a small battery then use the battery to power the pi.
    All the links are on the instructable. But i found this:
    http://www.maplin.co.uk/p/solar-charging-regulator-n82au
