Raspberry Pi Forum RASPBERRY PI INTERNATE CONNECTION PROBLEM BY ETHERNATE
  • Replies 21 replies
  • Subscribers 707 subscribers
  • Views 3883 views
  • ethernate
Dear Sir,
            I am new user of RASPBERRY PI . I purchase B+ & install raspian whizy as per your youtube video procedure. All are ok but internate not connected my bsnl broadband ethernate fixed land line. After set manually dhcp in static condition.ping 192.168.1.1 is ok but not update or upgrade or not open any browser , always say host problem.CMMAND hostname -i give me 127.0.1.1
I set manually
address 192.168.1.2
bcast 192.168.1.255
gatewaymask 255.255.255.0
gateway 192.168.1.1
after this ping 192.168.1.1 is response  but when sudo apt-get update  ""Err http:// raspberrypi.collabora.com wheezy Release.gpg could not resolve
failed to fetch http://mirrordirector.raspian.org/
at last
w: some index files failed to download.They have been ignored, or old ones used instead.
Kindly help me.
sujitkarmakarkuttus@gmail.com
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago
    You don't seem to have a DNS server setup
    Do this and your problem may be solved
    Sent from my iPhone
    e14 Contributor over 11 years ago in reply to Robert Peter Oakes
    Sir I set up manually by cmnd "sudo nano /etc/network/interfaces"
    & then address ,netmask, bcast, gateway select & dhcp change static but same.
    So how to set my dns or ovrcome tthis prblm.
  • mudz
    mudz over 11 years ago in reply to e14 Contributor
    Okay, If I am understanding it right it might be linked to this problem, but first tell me this: Do you connect your modem(internet) to pc using a connect dialup (icon as shown in image below)? or Internet is always on when you turn on your pc?
    e14 Contributor over 11 years ago in reply to mudz
    YES SIR ,
    I HAVE USER ID & PASSWORD.
    SIR I HAVE BSNL BROAD BAND & ALWAYS SAME TYPE DIAL UP COME & AFTER ID , PASSWORD CONNECT.
  • mudz
    Alright this is the problem, Now you need to change your modem settings.. Which Modem you are using?
    Try the following steps :-
    1) Open your modem page(default address) : type this ip in internet explorer 192.168.1.1 and hit enter.
    2) type admin, admin in both username and password field
    3) Now, following steps are according to the type of modem, I will take an example :
    > Now click on Internet connection
    > Under PVC Name tab you will find pppoe_0_35.. Click edit
    > Now click three times and don't change anything, after that you will find a page asking for SERVICE NAME, USERNAME & PASSWORD.
    > Service name : DATAONE, USERNAME = same username (you used in dialup connection), PASSWORD = same password(used in dialup connection).
    > connection type : always on.
    > Click next till you find apply and click apply.
    > now save and reboot your.
    That's It.. You can confirm it by rebooting your pc and you will find that internet is already connected (you don't need to connect dial up connection now)
    Wait !!! Note this before changing modem settings !!!
    --------------------------------------READ THIS BEFORE DOING ABOVE SETTINGS-----------------------------------------------
    After trying these settings If your modem(or say internet) does not works you can reset it back to default settings:
    There is a small hole(inside it is lies a reset button) on the back side of your modem near to the power jack or somewhere there. Just keep pressing that reset button(using some pin or needle as it is little deep) for ~ 8-10 seconds (at this you will find all MODEM will blink & then modem will restart)
    I can only hope now, that you haven't tried changing modem setting already( before reading this important note.) image
    sorry for delay to reporting (actually due to my net not availavail).
    Sir, I can not understand how to open my modem page on my raspberry pi.
    Kindly help me.My modem is "CITI ITI LIMITED" MODEL NO- DNA -A201BEI"
  • mudz
    You need to open modem page on your pc. Open internet explorer and Follow the instructions given on my last post.
  • mudz
    Before changing any modem settings please read red text instructions.
    Sir ,If I use morzila Then how to go your setting?
    many many thanks your quick response.
  • mudz
    start Mozilla or IE or chrome.. type 192.168.1.1 on address bar(address bar: where you type addresses like www.google.com)
    Now it will ask you for two things : username and password : type admin for both fields.
    That's it
