Raspberry Pi Forum RASPBERRY PI INTERNATE CONNECTION PROBLEM BY ETHERNATE
  • Replies 21 replies
  • Subscribers 707 subscribers
  • Views 3882 views
  • ethernate
Dear Sir,
            I am new user of RASPBERRY PI . I purchase B+ & install raspian whizy as per your youtube video procedure. All are ok but internate not connected my bsnl broadband ethernate fixed land line. After set manually dhcp in static condition.ping 192.168.1.1 is ok but not update or upgrade or not open any browser , always say host problem.CMMAND hostname -i give me 127.0.1.1
I set manually
address 192.168.1.2
bcast 192.168.1.255
gatewaymask 255.255.255.0
gateway 192.168.1.1
after this ping 192.168.1.1 is response  but when sudo apt-get update  ""Err http:// raspberrypi.collabora.com wheezy Release.gpg could not resolve
failed to fetch http://mirrordirector.raspian.org/
at last
w: some index files failed to download.They have been ignored, or old ones used instead.
Kindly help me.
sujitkarmakarkuttus@gmail.com
    e14 Contributor over 11 years ago in reply to e14 Contributor
    ok sir now I am understand.Thanku U very much.
    Sir , when i type 192.168.1.1 on address bar it always say "web page is not availavail".
  • mudz
    mudz over 11 years ago in reply to e14 Contributor
    Alright,
    Lets Debug the problem:
    1) Connect modem to pc via Ethernet cable.
    2) check the default gateway of modem in network connections by clicking on details of your Ethernet connection. (default is : 192.168.1.1, try this once again!!)
    3) type that address on your IE.
    4) If this does not works take the modem to the bsnl office and ask them to change it settings accordingly.(as you need direct internet feed from modem). Tell them, you don't want to use dial up setup. Ask them to make modem Internet always on.
    p.s.- I can tell you the whole procedure to do it yourself but I don't want to get in any trouble, its better and safe if you just take it to the bsnl office and ask them to that setting.
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor
    Type in URL:      http://192.168.1.1
    e14 Contributor over 11 years ago in reply to clem57
    HURRAH sir I am abel to connect to my raspberry pi by my broadband . Sir , verry verry thanks to you, you are only one person or your forum only one forum help me.
    At first I delete my dialup icon from my desktop after this delete frm network place then 192.168.1.1 type on my browser then admin ,admin then go to advance setting then wan then edit then ppoe settong then username & password, save & reboot my modem then connect my dirrect connect my pc as well as rapberry pi.
    Sir verry thanks to u.
    sir I do not want to disturb u but I hve more some querry ,can I ask to u?
    1) can I get video out put from B+ model like as b model ?
    2) when I connect internate & sudo apt-get update it is near about 124 wheezy update & continue. How many this?
    any mp3 songs & video not play .plugins problem. How to overcome ?
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to e14 Contributor
    The b+ has video out as hdmi and also on the audio jack (so I'm told), it was on an svideo connector on the B but it has been moved
    I am assuming your asking about that one as the hdmi is rather conspicuous
    Sent from my iPhone
  • clem57
    !) @Peter Oakes answered this one very well
    2) A downloaded version of wheezy is usually several months or possible a year old normally. I would not be surprised for the # of updates you had. Best off let it run and catch a coffee to relax. image
    3) On MP3/video, the codecs (software to decode the bits into a song or video) can be licensed. You may have to pay a small amount to get them from Raspberry Pi foundation and install a serial number. Usually takes a simple email back with information. Please check this for help or goto their site at the Raspberry Pi shop.
    Clem
    Sir, If I try to playing my youtube video & mp3 songs also necessary those licence for this? any chance to test my raspberry pi audio is ok or not?
    e14 Contributor over 11 years ago in reply to Robert Peter Oakes
    Sir , I am try to say ,if I use my CRT TV as MONITOR then can I get display from B+ model ?
    You told me I can use my AUDIO JACK, then kindly told me command or setting after sudo raspi-config .
    4-pole AV jack plug with connection configuration for Raspberry Pi B
    this is the pin out of the audio jack, as you can see, audio and video, I hope this helps
