Raspberry Pi Forum Raspbery Pi  with Rii i7 as Sonos remote
  • Subscribers 682 subscribers
  • Views 295 views
  • raspberry
  • rii
  • i7
  • sonos
  • remote
fozzyg
fozzyg over 11 years ago
I have connected a Rii I7 Mini  2.4Gh remote as a simple Sonos remote with the functions:
vol up/down
pause/play
next/prev  track
mute
start sonos with default station
http://www.kiwi-electronics.nl/index.php?route=product/search&search=i7
Rii mini X2[Wireless 2.4Ghz]
Instructions
Start with a working Raspberry Pi with Weezy (my version Linux pi-1 3.12.35+)
Connect the rii dongle and test if receiver available
lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 062a:1a9e Creative Labs                           ( the rii receiver)
Install pip python and socos librarys
sudo apt-get install python-pip
sudo pip install socos
test the connection to your sonos
socos list
my result I have  2 Play-1 in Stereo (Serre) and one  Sonos Amp  (Kamer)
pi@pi-1 ~ $ socos list
(1) 192.168.3.71    Kamer
(2) 192.168.3.72    Serre
(3) 192.168.3.73    Serre
test change volume
socos volume  192.168.3.72 +5   (volume up  on the stereo Serre Sonos)
Test your remote
++++++++++++++++++++++++++++++++++++    create file test_i7.py
vi test_i7.py
+++++++++++++++++++++++++++++++++ code
#!/usr/bin/python
import struct
import time
import sys
infile_path = "/dev/input/event" + (sys.argv[1] if len(sys.argv) > 1 else "0")
#long int, long int, unsigned short, unsigned short, unsigned int
FORMAT = 'llHHI'
EVENT_SIZE = struct.calcsize(FORMAT)
#open file in binary mode
in_file = open(infile_path, "rb")
event = in_file.read(EVENT_SIZE)
while event:
    (tv_sec, tv_usec, type, code, value) = struct.unpack(FORMAT, event)
    if type != 0 or code != 0 or value != 0:
        print("Event type %u, code %u, value: %u at %d, %d" % \
            (type, code, value, tv_sec, tv_usec))
    else:
        # Events with code, type and value == 0 are "separator" events
        print("===========================================")
in_file.close()
+++++++++++++++++++++++++++++ code end +++++++++++++++++
test the keyboard buttons for volume up
python test_i7 1
press a button
test the mouse buttons
python test_i7 0
move mouse
Result  for vol up
pi@pi-1 ~ $ python test_i7.py 1
Event type 4, code 4, value: 786665 at 1422559215, 765193
Event type 1, code 115, value: 1 at 1422559215, 765193
Event type 4, code 4, value: 786665 at 1422559215, 901205
Event type 1, code 115, value: 0 at 1422559215, 901205
Simple  control script for
vol up
vol down
play-pause
home   (start sonos with preset radio station at volume 10)
+++++++++++++++++++++++++++++create file  i7.py
vi i7.py
#!/usr/bin/python
import struct
import time
import sys
from soco import SoCo
meta_template = """
<DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/"
   xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"
   xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"
   xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/">
   <item id="R:0/0/0" parentID="R:0/0" restricted="true">
      <dc:title>{title}</dc:title>
      <upnp:class>object.item.audioItem.audioBroadcast</upnp:class>
      <desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/">
         {service}
      </desc>
   </item>
</DIDL-Lite>' """
tunein_service = 'SA_RINCON65031_'
serre = SoCo('192.168.3.72')
infile_path = "/dev/input/event1"
FORMAT = 'llHHI'
while event:
      try:
         if type == 1 and code == 115 and value == 1:
            print ("Vol Up")
            serre.volume =  serre.volume + 2
         elif type == 1 and code == 115 and value == 2:
            print ("Vol Up Cont")
            serre.volume =  serre.volume + 1
            time.sleep(0.1)
            in_file.close()
         elif type == 1 and code == 114 and value == 1:
            print ("Vol Down")
            serre.volume =  serre.volume - 2
         elif type == 1 and code == 114 and value == 2:
            print ("Vol Down Cont")
            time.sleep(0.1)
            in_file.close()
         elif type == 1 and code == 142 and value == 1:
            print ("Off")
            serre.mute = False
            serre.stop()
            serre.volume = 10
         elif type == 1 and code == 164 and value == 1:
            print ("Play Pause")
            transport_info = serre.get_current_transport_info()
            if transport_info['current_transport_state'] == 'PLAYING':
               serre.stop()
            else:
               serre.play()
               serre.mute = False
         elif type == 1 and code == 164 and value == 2:
            print ("Play Pause Cont")
         elif type == 1 and code == 104 and value == 1:
            print ("Page Up")
         elif type == 1 and code == 104 and value == 2:
            print ("Page Up Cont")
         elif type == 1 and code == 109 and value == 1:
            print ("Page Down")
         elif type == 1 and code == 109 and value == 2:
            print ("Page Down Cont")
     elif type == 1 and code == 103 and value == 1:
            print ("Up")
         elif type == 1 and code == 108 and value == 1:
            print ("Down")
         elif type == 1 and code == 105 and value == 1:
            print ("Left")
            serre.previous()
         elif type == 1 and code == 106 and value == 1:
            print ("Right")
            serre.next()
         elif type == 1 and code == 28 and value == 1:
            print ("Ok")
         elif type == 1 and code == 28 and value == 2:
            print ("Ok Cont")
         elif type == 1 and code == 172 and value == 1:
            print ("Home")
            stations = serre.get_favorite_radio_stations( 0, 100)
            serre.play()
            serre.volume = 10
            serre.mute = False
            for fave in stations['favorites']:
               if fave['title']=='NPO Radio 2':
                  print fave['title']
                  uri = fave['uri']
                  uri = uri.replace('&', '&amp;')
                  metadata = meta_template.format(title=fave['title'], service=tunein_service)
                  serre.play_uri(uri,metadata)
         elif type == 1 and code == 127 and value == 1:
            print ("List")
      #except serre.exceptions.SoCoUPnPException:
         #print "exception caught", soco.exceptions.SoCoUPnPException
      except:
          print "error"
in_file.close()
++++++++++++++++++++++++++++++++ end
+++++++++++++++File for deamon start create file  in /home/pi
vi i7.sh
++++++++++++++++++ code ++++++++++
#!/bin/sh
script='/home/pi/i7.py'
exec /usr/bin/python $script
sudo chmod 755 i7.sh
++++++++++ create /etc/init.d/ i7
sudo vi  /etc/init.d/i7
+++++++++++++++++ code ++++++++++++++++++
#!/bin/sh
### BEGIN INIT INFO
# Provides: myservice
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Put a short description of the service here
# Description: Put a long description of the service here
### END INIT INFO
# Change the next 3 lines to suit where you install your script and what you want to call it
DIR=/home/pi
DAEMON=$DIR/i7.sh
DAEMON_NAME=i7
# Add any command line options for your daemon here
DAEMON_OPTS=""
# This next line determines what user the script runs as.
# Root generally not recommended but necessary if you are using the Raspberry Pi GPIO from Python.
DAEMON_USER=root
# The process ID of the script when it runs is stored here:
PIDFILE=/var/run/$DAEMON_NAME.pid
. /lib/lsb/init-functions
do_start () {
log_daemon_msg "Starting system $DAEMON_NAME daemon"
start-stop-daemon --start --background --pidfile $PIDFILE --make-pidfile --user $DAEMON_USER --chuid $DAEMON_USER --startas $DAEMON -- $DAEMON_OPTS
log_end_msg $?
do_stop () {
log_daemon_msg "Stopping system $DAEMON_NAME daemon"
start-stop-daemon --stop --pidfile $PIDFILE --retry 10
log_end_msg $?
case "$1" in
start|stop)
do_${1}
restart|reload|force-reload)
do_stop
do_start
status)
status_of_proc "$DAEMON_NAME" "$DAEMON" && exit 0 || exit $?
echo "Usage: /etc/init.d/$DAEMON_NAME {start|stop|restart|status}"
exit 1
esac
exit 0
sudo chmod  755 i7
make deamon start a boot
sudo update-rc.d i7 defaults
docu on Socos  library
The soco module — SoCo (Sonos Controller) 0.10 documentation
Good luck , it works for me
i7.py.txt.zip
