Raspberry Pi Forum Raspberry Pi and Existing Accenta Gen 4 Alarm
  • Replies 39 replies
  • Subscribers 710 subscribers
  • Views 7293 views
  • pi
  • accenta
  • alarm
Hi All,
I'd like to connect my existing alarm (HONEYWELL ADE ACCENTA MINI LCD BURGLAR ALARM PANEL: Amazon.co.uk: Kitchen & Home) to my pi, so that I can monitor the alarm remotely.  The panel has a connection for a "dialler" so im thinking of connecting the pi via that.
As well as the status of the alarm, I'd like to make use of the PIRs so that I can integrate them with my home automation.
Thanks in advanced.
    shabaz over 11 years ago
    Hi Shyam,
    Just bear in mind the alarm will probably go off when you take the panel off : ) A pain to deal with unless you're ready with the procedure to reset (will be in the manual, and if you remember the codes!).
  • gadget.iom
    gadget.iom over 11 years ago in reply to shabaz
    Excellent point shabaz.
    There should be a tamper spring somewhere on the board. Removing the panel cover causes the spring to de-tension and the switch to open-circuit.
    You will need to follow the procedure below in order to silence/reset the tamper condition.
  • Problemchild
    Problemchild over 11 years ago in reply to shabaz
    Also if he interfaces to the sensors in such a way that breaks the contact at any point will also set it off.
    Not that he needs to as he should be able to pick up the PIR input from the alarm directly...Probably;y best to use an optoisolator as to give very little chance that anything will come across from one circuit to the other even if misconfigured.
    shabaz over 11 years ago in reply to Problemchild
    There are so many wires inside those panels sometimes, I think you're right, there may be a risk of nudging a cable and causing some intermittent issue from that moment on. Depends on how good the installation was!
    I was thinking a similar thing, an LDR or phototransistor on the LED that is lit or flashes when the alarm is activated, that way no need to even open the panel, and it doesn't matter if it looks ugly if the panel is hidden away somewhere anyway.
    e14 Contributor over 11 years ago in reply to shabaz
    Thanks all for your advise...will let you know how it goes.
    shabaz is that your git repo I posted a link of?
    shabaz over 11 years ago in reply to e14 Contributor
    Hi Shyam,
    Good luck!! No, its not mine, I've not seen that one before.
    Thanks image
    e14 Contributor over 11 years ago in reply to e14 Contributor
    I'm assuming I can just get this pack of resistors which will cover the ones I need:
    http://www.maplin.co.uk/p/e3-resistor-480-piece-pack-n63bh
    I would order from UK Farnell, but one of the resistors (2k2) is not stocked in the UK image
  • gadget.iom
    gadget.iom over 11 years ago in reply to e14 Contributor
    My apologies, I should've checked stock levels image
    You could buy that kit, though it doesn't include 330Ω resistors. You could substitute for a similar value.
    Farnell do have some 2k2 in stock here: MF25 2K2 - MULTICOMP - RESISTOR, 2.2K, 0.25W, 1% | Farnell element14
    e14 Contributor over 11 years ago in reply to gadget.iom
    Thanks Paul
