Raspberry Pi Forum Serial Communications Question from NOOBIE?
  • Subscribers 677 subscribers
  • Views 355 views
  • teraterm
  • serial
  • communication
I'm interested in communicating with a serial device using my RPi B+.  I'm not sure about the best way to go about it.  Currently, I am using TeraTerm on Windows PC.  Would like to switch to RPi and suitable communications package.  Can anyone offer suggestions?
Galen (Respectfully)
  • clem57
    clem57 over 10 years ago
    You can do serial communications with USB or GPIO pins. Look for TX and RX. What is the other end you are talking with?
    Clem
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago
    Are you asking how to communicate with the PI from other devices or use the PI to communicate with other things like an Arduino, ADC, DAC etc
    in which case you could look at the SPI interface or the I2C as viable methods
    What is it your trying to communicate with ?
  • royleith
    royleith over 10 years ago
    If you just want ordinary serial port communication via a standard port, then I have been successful with a USB serial interface and the putty program (It's a clone of the Windows PuTTY program).
    You need to select serial communication in putty with the correct start and stop bits, parity and speed. You also need to point it to the correct serial device which, for me, is /dev/ttyUSB0. You need to hunt in /dev after you have plugged in the interface USB lead.
