Raspberry Pi Forum Another Raspberry Pi PSOne Project
  • Replies 8 replies
  • Answers 2 answers
  • Subscribers 708 subscribers
  • Views 1726 views
  • raspberry_pi2
  • raspberry_pi_space
  • psone
paulhopgood
paulhopgood over 11 years ago
Hi everyone,
I'm pretty new to this community and haven't been able to quite find the answers I'm looking for through searching so thought I'd create a post.
I'm going to start work on a project involving putting a Raspberry Pi 2 inside a PSOne shell with the PSOne portable screen attached to it.
The PSOne has a 7.5v power supply which can power the screen at the same time. I'd like to continue using this but have it power the Raspberry Pi. I think I need to add a Step-down Buck Converter - 5v between the power supply and the Pi (after the screen in the circuit though). Can someone confirm I'm not doing something completely wrong.
If people are interested I'll post more about the project as it progresses. I'm sure I'll have more questions to ask too.
  • gadget.iom
    0 gadget.iom over 11 years ago
    Sounds feasible. Something like this should work:
    http://uk.farnell.com/tracopower/tsr-1-2450/converter-dc-dc-5v-1a-sip/dp/1696320
    Just be aware of the 1A maximum current output, and the 6.8V minimum input voltage.
  • clem57
    0 clem57 over 11 years ago
    Another idea is this https://www.raspberrypi.org/forums/viewtopic.php?t=8003 which uses a voltage regulator up to 22V input.
    Clem
  • paulhopgood
    0 paulhopgood over 11 years ago
    Thanks for the quick replies and for putting my mind to rest.
    I think I looked at the TSR 1-2450 before and was a little concerned about the current output too. I found this: https://www.adafruit.com/products/1385 which looks like a combination of both your replies, Paul and Clem.
    Thanks again
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to paulhopgood
    Looks good!
  • clem57
    0 clem57 over 11 years ago in reply to paulhopgood
    This is a perfect solution from a good supplier too. I did not want to "push" a solution, rather suggest a type for you. Glad to help.
    Clem
    Here's one I'm working on not a PsOne but a psx  http://s4.postimg.org/leb206dzx/image.jpg Currently has around 6000 Roms on a 1tb hdd, 4 usb ports, wifi, Bluetooth. And still plenty of hdd space for more.
    Sorry to jump your post.
  • clem57
    Hi Paul Hopgood
         How is your project coming along?
    C
  • spannerspencer
    0 spannerspencer over 11 years ago in reply to e14 Contributor
    What's it got inside, edr1ck? Is that Raspberry Pi 2 powered as well? That's a hell of a spec, and a stunning retro machine! I'm really into gutting old consoles and kitting them out with new innards image
    Whatever it's got in the casing, I'd love to see inside this and to hear about your build -- post it in a blog here on the community. You'll get some great feedback, guaranteed! (and probably some element14 swag from me, too image).
