Raspberry Pi Forum Use as a guitar pedal.
  • Replies 13 replies
  • Subscribers 707 subscribers
  • Views 2259 views
  • logic
  • audio
  • guitar
  • cirrus
  • line
  • raspeberry_pi_accessories
  • noise
  • card
  • out
  • pedal
I was hoping to use the Cirrus board as a digital effects guitar pedal. I was planning on using line in and line out since the connections make things very simple. However, I have run into some problems with the line out to guitar amplifier connection. First of all, though, I tried recording through line in. When I played what I recorded through my computer speakers it sounded pretty good. When I connected the line out to my guitar amps (Vox AC15C1 / Marshall MG15FX) it had a significant amount of noise coming from the board. I then thought it might be the cord. I tested this by connecting my laptop to my amp with the same cord and playing the same file from my laptop, but this time there was no noise. I checked and the output impedance of the RPi and the Vox are both 15 ohms. One thing I was thinking might be a problem was the max capacitive load for the line out, which was 2 nF, but I haven't been able to find anything about that related to the Vox.
So does anyone know what could be causing noise from the line out only when it is connected to a guitar amplifier? And has anyone tried to use the Cirrus board with the RPi as a guitar pedal?
  • screamingtiger
    0 screamingtiger over 11 years ago
    What type of power supply are you using for the Pi?  I'd recommend some filter caps on both the line out and the power supply.
    I would bet the power supply is noisy.
    0 e14 Contributor over 11 years ago in reply to screamingtiger
    So I tried out a different power supply, as I was connecting it rather sketchily, and it helped a little bit. What ended up fixing it was plugging the amplifier into the same power strip as the RPi. Essentially meaning the distortion was because they weren't sharing a common ground. However, I don't think I necessarily want to plug them into the same outlet every time. So what I think I need to do is ground the Raspberry Pi. I haven't done the research yet, but i'm guessing there are a lot of posts regarding this.
  • screamingtiger
    0 screamingtiger over 11 years ago in reply to e14 Contributor
    That makes sense.  Also cool project, are you planning to show us some more details?  I always wanted to do my own effects box, I am curious how you are implementing the effects?
    0 michaelkellett over 11 years ago in reply to e14 Contributor
    If that is happening you have an earth loop problem and you might do better to invest in an audio isolating transformer - you should have one between your guitar and any mains powered (especially experimental) equipment any way. If you are powering the RPI using low cost USB chargers it isn't very safe (some of these chargers don't comply with UK or EU (or anyone elses's) safety regulations. Using a local earth leakage trip (or residual current circuit breaker (RCB) may save your life.
    Traditional guitar pedals are battery powered and very safe. Unfortunately a transformer between the guitar and the first chunk of electronics will change the sound, one between the PI and the amp will probably make no audible difference but might get rid of the noise problem.
    Between the PI and the amp
    Ground Loop Isolator | Rapid Online
    Pi power supply plugged into this
    R2804 - PRO ELEC - EXTENSION LEAD, 4 GANG, RCD, 2M | Farnell element14
  • sqkybeaver
    0 sqkybeaver over 11 years ago
    i agree with Michael, you should try an isolating transformer on the output. you can salvage one from an old modem. possibility even use a balanced line(xlr) to further reduce common mode noise.
    I gave up on anything other than battery power for pedals and active instruments. a shielded box will no doubt improve things.
    0 Jan Cumps over 11 years ago
    I'm a bit confused about the shared ground and ground loop comments.
    Isn't the Pi's power supply isolated - Not connected to your house's ground?
  • sqkybeaver
    0 sqkybeaver over 11 years ago in reply to Jan Cumps
    when everything is grounded separate points, eg; amp at wall socket, rpi on another socket. there can be a potential(voltage) difference at between these points when they should be the same potential(ground in this case), this will cause current to flow between these points.
    the idea of the transformer is to isolate the grounds from each other to eliminate any ground current between these spots. this can be a deadly problem in certain situations.
    0 Jan Cumps over 11 years ago in reply to sqkybeaver
    But is that Pi grounded? Isn't Ryan using your typical isolated power supply for the Pi?
  • sqkybeaver
    most wall-wart supply's are floating outputs. very very very few have one or the other output tied to mains ground(earth) the cheaper phone charger types are switching and are not guaranteed to be clean, or safe.
    Ryan, what power supply are you using?
    0 e14 Contributor over 11 years ago in reply to sqkybeaver
    I'm using this guy: http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-MWS158-0502200UC-MIC-/28-17985?t=2&utm_expid=8634549-27.0czCl7fSQamjILoiAH9mgA.1&utm_referrer=https%3A%2F%2Fwww.google.com%2F
    I'm a little confused about why the transformer would help. How would it isolate the grounds from each other, and, I might be reading it wrong, I feel like I want the grounds to be connected. Also I'm not exactly sure what I'm looking for. It seems that a suitable transformer may be over $50 or under $10 (suitable transformer for an audio isolation transformer?). Here is another one that seems more focused on guitars: GuitarCenter
    To Joey: if I'm able to get it working I would be very happy to post the info about what I did, however it seems like I have a lot of work to and I'm headed back to college tomorrow, so I'm not sure I'll have a ton of time to make significant progress over the next couple of months.
