Raspberry Pi Forum Help start up Sense hat - thanks
  • Replies 8 replies
  • Subscribers 705 subscribers
  • Views 1631 views
  • genesisofpi
  • raspberry_pi_getting_started
entering the lines in the first program gives the error message
....line 14 in module
   from PIL import Image # pillow
ImportError:  No module named PIL
    I get this same error - did you find a workaround?
    Hi Richard,
    Have you done:
    sudo pip-3.2 install pillow
    Let me know how it goes...
    Peter
    Thanks Peter, that did the trick!
    When I try and install Pillow,
    it aborts with:
    File "setup.py", line 515, in build_extensions
        % (f, f))
    ValueError: --enable-jpeg requested but jpeg not found, aborting.
    this is on an up-to-date Raspberry Pi system.
    any clues?
    --bob
    Bob,
    I get exactly the same error message as you. Are you any closer? I'm still looking for the answer!
    Claire
    Hi!
    I got the exactly the same problem, you're probably missing the libjpeg library. I did
      aptitude install libjpeg-dev
    and that worked.
    In case, you're not familiar with it, you can run in RPi (standard NOOBS install): sudo apt-get install libjpeg-dev
    Thanks Tudi
    I got that suggestion and it's worked. So pleased image
    Tudi--
    Many thanks! That did it!
    --bob k6rtm
