Raspberry Pi Forum Does the basic Raspberry Pi 2 at $35 comes with power supply?
  • Subscribers 707 subscribers
  • Views 585 views
  • raspberry
  • pi
  • 2
Does the basic Raspberry Pi 2 at $35 comes with power supply?  If not, what are some of the recommended solutions?  Thank you.
  • Problemchild
    0 Problemchild over 10 years ago
    No it doesnt. Try the micro USB charger for your phone assuming it is rated for 1A current or more.
    Failing that any such carger with such a rating should be OK
  • johnbeetem
    0 johnbeetem over 10 years ago
    The RasPi 2 with its quad-core processor may use a lot more current than a RasPi B+.  Actual current depends on what the CPUs are doing, and what USB peripherals are powered through the RasPi.  1A current is probably enough for most users, but some RasPi 2 applications may need more.  A 700 mA charger is marginal.  You also might have a problem with the Micro USB cable: many of those have very thin conductors which can cause a significant voltage drop at 1A.  Unfortunately, it's hard to tell what you're going to get with most USB cables.
    I'd try a phone charger like John Alexander suggests.  If that's not enough, Adafruit has a nice 2A power supply with a good USB cable.  I haven't tried that particular supply myself, but I've had good luck with Adafruit.
    0 e14 Contributor over 10 years ago in reply to Problemchild
    Thank you very much for your replies John Alexander and John Beetem.  I am looking into this as a Christmas gift for my sons.  Glad to know that a separate power supply is needed.
