Raspberry Pi Forum PiFace RTC on Raspberry Pi2: still losing time on reboot!
  • Replies 24 replies
  • Subscribers 709 subscribers
  • Views 4491 views
  • clock
  • pi
  • rtc
  • raspberrypi
  • date
  • settings
  • piface
Hi!
I bought a PiFace RTC and I'm trying it on a Raspberry Pi 2 Model B. I followed the many guides I found on the internet, but I'm still having problem with the date: when I reboot, the system time is always set to Jan 1, 1970! It seems to be in a reset condition.
The I2C detects well the device at the address 0x6F, and the battery is ok.
After the execution of the .sh script as written in the PiFace RTC user guide, I set the actual date with "sudo date -s "12 jan 2016 10:30:00",
set the i2c module from raspi-config.
I triyed in so many ways but I really can't understand what I'm doing wrong!
Any idea would be appreciated!
Andrea.
  • clem57
    0 clem57 over 10 years ago
    You did not install startup script. See https://github.com/piface/PiFace-Real-Time-Clock for install script.
    Clem
    0 e14 Contributor over 10 years ago in reply to clem57
    Hi Clem,
    Thank you.
    Yes, I installed the script, either automatically (connected to the internet) and manually (procedure described in the link you provided). Unfortunately, nothing is changed..
    After installing the script with
    $ sudo ./install-piface-real-time-clock.sh
    This message appears:
    Changing /etc/rc.local to load time from PiFace Clock.
    Now *reboot* and set your clock with
    sudo date -s "14 JAN 2014 10:10:30"
    So, I enabled the I2C by running
    $ raspi-config
    as described in the link you provided, then I rebooted and set the date with sudo date -s ...
    Then:
    sudo reboot
    The new date seems to be not retained!
    $ date
    Gives to me:
    gio 1 gen 1970, 01.00.18, CET
    It still not working image!
    I checked the i2c with:
    $ i2cdetect -y 1
    this is the output:
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
    00:          -- -- -- -- -- -- -- -- -- -- -- -- --
    10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
    60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- UU
    70: -- -- -- -- -- -- -- --
    As far as I remember, this means that the PiFace RTC seems to be well detected...
    I really can't understand where can be the problem, what am I doing wrong?
    Thanks in advance,
    Andrea
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago in reply to e14 Contributor
    Do you have pullups on the I2C lines, if not you should, they will help alot
    about 5K-10K should work if the RTC is closs to the PI
    0 Robert Peter Oakes over 10 years ago in reply to Robert Peter Oakes
    Just looked at the board and it appears to have some so perhaps a different problem ??
    0 e14 Contributor over 10 years ago in reply to Robert Peter Oakes
    Thanks Peter,
    yes, perhaps it's a different problem.
    For testing purpose, I tryied to set the date with:
    sudo date -s "14 jan 2016 08:55:30"
    then I copy the time to the RTC with:
    sudo hwclock -w
    Then I read the RTC with:
    sudo hwclock -r
    Ok, the time displayed is correct.
    After that, I shut down, wait for five minutes and I power up.
    I try to read the RTC once more:
    sudo hwclock -r
    It gives:
    gio 1 gen 1970, 01.00.31, CET
    and sudo hwclock -r gives:
    hwclock: The Hardware Clock registers contain values that are either
    invalid (e.g. 50th day of month) or beyond the range we can handle (e.g. Year 2095).
    So the time has not being retained! I really don't know where the problem can be image
    Please help!
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    # NAME: start_on_boot
    # DESCRIPTION: Load the I2C modules and send magic number to RTC, on boot.
    start_on_boot() {
      echo "Changing /etc/rc.local to load time from PiFace Clock."
      # remove exit 0
      sed -i "s/exit 0//" /etc/rc.local
      if [[ $RPI_REVISION == "1" ]]; then
      i=0 # i2c-0
      else
      i=1 # i2c-1
      fi
      cat >> /etc/rc.local << EOF
    modprobe i2c-dev
    # Calibrate the clock (default: 0x47). See datasheet for MCP7940N
    i2cset -y $i 0x6f 0x08 0x47
    modprobe i2c:mcp7941x
    echo mcp7941x 0x6f > /sys/class/i2c-dev/i2c-$i/device/new_device
    hwclock -s
    EOF
    The script above is not setting /etc/rc.local correctly. Please show the contents here. Ty
    Clem
    Hi Clem,
    where have to be placed the script you posted? Is it automatically executed at the startup?
    My /etc/rc.local contains the code below (is it correct? Perhaps some problems here?)
    _IP=$(hostname -I) || true
    if [ "$_IP" ]; then
      printf "My IP address is %s\n" "$_IP"
    fi
    modprobe i2c-dev
    i2cset -y 1 0x6f 0x08 0x47
    echo mcp7941x 0x6f > /sys/class/i2c-dev/i2c-1/device/new_device
    hwclock -s
    modprobe i2c-dev
    hwclock -s
    #Andrea
    echo mcp7941x 0x6f > sys/class/i2c-adapter/i2c-1/new_device
    ( sleep 2; hwclock -s ) &
    modprobe i2c-dev
    hwclock -s
    #added by myself
    sudo hwclock -s
    modprobe i2c-dev
    hwclock -s
    #added by myself
    sudo hwclock -s
    modprobe i2c-dev
    hwclock -s
    modprobe i2c-dev
    hwclock -s
    Thanks again!
  • clem57
    Ok you have too much. remove all up to last "#  Calibrate" using nano. save and reboot. Should work
    Clem
    I will try and let you know if it can solve the problem. Thanks!
    Hi Clem,
    I modified my /etc/rc.local according with your tip. At the first reboot the time was ok! But with the successive shutdown and reboots, time and date was still not retained! Is it possible?
    Now my /etc/rc.local is:
    #Print the IP address
    if [ "$_IP" ]; then
    fi
    #Calibrate the clock (default: 0x47). See datasheet for MCP7940N
    hwclock -s
    Do you think it should be ok?
    Thanks.
