Raspberry Pi Forum Using a second SDIO on PiZero
  • Subscribers 706 subscribers
  • Views 2080 views
cto
cto over 10 years ago
Is the SDIO lines supporting the SD card on the raspberry PiZero the same as the ones on P1?
Is there a way to use those SDIO on P1 to support WiFi?
  • clem57
    0 clem57 over 10 years ago
    Front Raspberry Pi zeroView 2
    These appear to be the same as the Micro SD on Pi2 not the regular sized P1 SD card.
    Clem
  • cto
    0 cto over 10 years ago in reply to clem57
    I know, my question is about the SDIO bus. The processor supports 2 SDIO devices; one is the microSD for booting, however P1 has SDIP available at GPIO22-27 (15,16,18,22,37,13).
    My question is are the SDIO lines on P1 is related to the second SDIO device or are they the same ones connected to the micro SD?
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago
    The SD cards are primaraly a SPI device, as such you technically could parallel anouther device as long as you use a seperate chip select line ut this would then require special driver to know what to use for it. It seems much simpler to use a USB Hub of sorts or an ESP8266 board on the serial lines, depending on what your trying to acheive
