Raspberry Pi Forum RPI personal assistant software
  • Answers 2 answers
  • Subscribers 704 subscribers
  • Views 813 views
I want to use the RPi and make a assistant app(like Siri which can have a conversation type way and activated by a command i.e. for Siri you say Siri and for google now you say Okay Google ) but I also want to do other objects. For example when someone says hello, the assistant software replies hello and makes the LED dim or bright. Also it would be nice to use object recognition and object tracking, I'm using a raspberry pi 2.
  • mconners
    0 mconners over 10 years ago
    I haven't used it, but look into
    Sirius: An Open Intelligent Personal Assistant
    here is a link to their git repo
    https://github.com/claritylab/lucida
    Mike
    0 e14 Contributor over 10 years ago in reply to mconners
    Will you be able to run cortona/sirius on it and still have a program to control the gpio pins at the same time?
  • mconners
    0 mconners over 10 years ago in reply to e14 Contributor
    You should be able to.
    Mike
    Will cortona be supported by microsoft's IoT? And if yes than will it be as advanced as your normal one on the windows phone
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    This is a crystal ball question since M$ is about the bottom line. If it sells more, yes is the answer! As to more advanced I would say no. But you make your choice independent of M$ since they will do so on their own time frame.
    Clem
