Raspberry Pi Forum Pi NoIR camera board, which driver and sensor does it use?
  • Replies 8 replies
  • Subscribers 707 subscribers
  • Views 1446 views
  • driver
  • camera.
  • camera sensor
I am trying to integrate the Pi NoIR camera board in an embedded platform (other than the raspberry). Could you indicate which sensor and driver does it use? Is the driver opensource?
  • rew
    0 rew over 10 years ago
    The camera was said to be coming for a long time before it actually became available. The story was that the raw bytes from the camera need significant processing before they become "useful".
    In the case of the raspberry pi, this processing is done by a closed-source module inside the videocore processor.
    0 e14 Contributor over 10 years ago in reply to rew
    Thanks for the information.
    I think that the camera uses the OmniVision OV5647 sensor. Do you know if that is correct? Do you know if there is a driver for that sensor in the raspberry kernel?
  • rew
    0 rew over 10 years ago in reply to e14 Contributor
    I remember hearing about the sensor's identifing number. OVxxxx, so what you're saying could very well be correct. A quick google search should verify that.
    As I've said: There is no kernel driver for that chip, as the sensor is handled by the videocore. Raspberry pi applications just communicate with the videocore. If they need to go through the kernel for that I don't know. Maybe there is a video-for-Linux driver that communicates with the videocore in this situation. In any case, the kernel does not meddle with the OVxxxx sensor.
    update: Here I did the search for you. One of the links that pops up is: https://www.raspberrypi.org/forums/viewtopic.php?f=43&t=122759
    Jamesh there is "alluding" to the GPU-code being closed source. He's one of the engineers involved in writing that stuff so you'd better take what he says as valid....
    I see, that makes it clear. Thanks
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    What processor were you planning to use?
    Clem
  • rew
    Ah. Found another authorative link: https://www.raspberrypi.org/blog/creating-the-camera-board/
    0 e14 Contributor over 10 years ago in reply to clem57
    i.MX6
  • clem57
    From NXP or prior Freescale for that processor. Looking above they have a 16bit CSI. image
    Camera Interface
       o Types: 2x 20-bit parallel, MIPI-CSI2 (4 lanes), three simultaneous inputs
    Freescale i.MX 6 Series with ARM Cortex A9Tm for Consumer and General Embedded
    Freescale i.MX 6 Development Platforms Software Download Center image for software.
    https://boundarydevices.com/debian-installer-on-i-mx6/
