Raspberry Pi Forum raspberry pi python robotics keyboard commands help
  • Subscribers 705 subscribers
  • Views 766 views
  • python
  • python raw input
  • robots
  • raspberry pi
  • keyboard input
hello, I've been working on a raspberry pi powered robot I've been trying to write a simple script in python but I have not been able to control the pi from the keyboard
the last part of the script is what I need help with.
the script I've been using
import RPi.GPIO as GPIO
import time
import sys
import Tkinter as tk
def init():
  GPIO.setmode(GPIO.BOARD)
  GPIO.setup(7,GPIO.OUT)
  GPIO.setup(11,GPIO.OUT)
  GPIO.setup(13,GPIO.OUT)
  GPIO.setup(15,GPIO.OUT)
def w()
  GPIO.output(7, False)
  GPIO.output(11, True)
  GPIO.output(13, True)
  GPIO.output(15, False)
  time.sleep(tf)
  GPIO.cleanup()
def s()
  GPIO.output(7, True)
  GPIO.output(11, False)
  GPIO.output(13, False)
  GPIO.output(15, True)
  time.sleep(tf)
  GPIO.cleanup()
def key_input(event):
  init()
  print 'Key:' event.char
  Key_press = event.char
  sleep_time = 0.030
  if Key_press.lower() == 'w':
  w(sleep_time)
  elif key_press.lower() == 's':
  s(sleep_time)
  else:
  pass
command = tk.Tk()
command.bind('<key_press>', key_input)
command.mainloop()
  • clem57
    0 clem57 over 10 years ago
    w(sleep_time)     but: def w()
    If you pass a parameter, you must have it in the def part as well!
    Clem
