Raspberry Pi Forum What is a good pressure plate for RPi3?
  • Subscribers 705 subscribers
  • Views 1089 views
mrbartucz
mrbartucz over 10 years ago
Hi, my assistant and I are hoping to create a doormat that triggers events (think halloween). Can someone give us advice on the best way to do that? We were thinking of putting some kind of pressure sensor underneath, but the only ones we've found are really tiny. We welcome all suggestions (trigger beam, etc). Thanks!
    0 DAB over 10 years ago
    Why not use a large capacitor sheet connected to a PSOC and use the capacitive sense capability to indicate when someone steps on the sheet?
    It is simple, inexpensive and makes a good home project for the kids.
  • mrbartucz
    0 mrbartucz over 10 years ago in reply to DAB
    Thanks for the suggestion. Sorry for the newb question, but where could I find such a sheet?
    0 dougw over 10 years ago in reply to mrbartucz
    I'm not sure how long it would last, but 2 sheets of aluminum foil separated by something a bit spongy (like a rug or a towel) should work for a while. It may be more robust if you use some metal mesh (window screen) or chicken wire instead of foil, but you will need to test to ensure continuity across the surface first. Some furnace filters have expanded metal mesh grills.
    You could also use a vibration sensor:
    Tis The Season For Arduino
  • mrbartucz
    0 mrbartucz over 10 years ago in reply to dougw
    Thanks!
    0 DAB over 10 years ago in reply to mrbartucz
    Easy, take a plastic sheet twice the width of your walkway.
    Cut a sheet of aluminum foil the width of your walkway.
    Put the aluminum foil between the two halves of the plastic sheet.
    Run a wire from a capacitive sense input and use an alligator clip to attach it to the aluminum foil.
    Calibrate, and you are ready to go without worrying about rain or snow getting to the aluminum foil.
