Raspberry Pi Forum Compute Module stuck in kernel panic.
  • Subscribers 707 subscribers
  • Views 966 views
inter_asp_ed2
inter_asp_ed2 over 10 years ago
I have read and re-read the documentation provided by the vendors and programmers of the RPi compute module. However, I haven't seen any clear and precise instruction on how to extricate a compute module stuck in 'kernel panic'
So, my question is this, what is the most accurate way to restore/reset an raspberry pi's compute module, that is stuck in an endless loop. If there isn't one, do I dump and move on, because it can't be recovered.
  • bprewit
    0 bprewit over 10 years ago
    I haven't used the rPi compute module, but I suspect there's one of two things happening; either the hardware is bad or the boot image is corrupt.
    Since fixing the boot image is easier, before giving up on the hardware I'd try re-flashing it.
    Directions are here.
  • inter_asp_ed2
    0 inter_asp_ed2 over 10 years ago in reply to bprewit
    Thank you Bruce Prewit, for your reply to my query. This comment is only for basic information: I have been reading and following the instructions that you have pointed out to me in the link you provided, over and over and over., etc, and et all.I have used Windows 8.1, Ubuntu 16.04 LTS, and Raspberry Pi 2 B+ and P3 B+. I'll re-read the instructions again and follow them to the letter again; I don't expect a change from what I have seen thus far, but I can hope it will be different this time around.
  • bprewit
    0 bprewit over 10 years ago in reply to inter_asp_ed2
    There's a saying .. "Insanity is doing the same thing over and over, expecting different results".  If you've tried re-flashing the OS image then there must be something else.
    I'd try this .. it'd also help if you could paste any output appearing before the "kernel panic" message.
    0 e14 Contributor over 10 years ago in reply to inter_asp_ed2
    Change the power source to normal charger. Power that comes in Raspberry Pi packet is not good.
